Engine RPM question on new CK30
   / Engine RPM question on new CK30 #1
TForan
Mi
Kioti CK30HST
What's the significance of the red triangle on the tach? Is that a redline ,not to be exceeded? What RPM do you gentleman usually run yours at?
   / Engine RPM question on new CK30 #3
You can't run that diesel engine at too high RPM. They are designed to run full out all day and night 24/7.
Bigtractor said it right. That's where you need it for most PTO implements like the mower, a tiller etc. John
   / Engine RPM question on new CK30 #4
Bigtractor and KiotiJohn have the 540 PTO speed with the triangle. Check your owner's manual. It should tell you the same.
As stated before by many of the members, don't lug the engine. That's worse than running it at a faster rpm. My CK30HST is new with 9 hours now. I run it around 1500-2000 if I'm not doing any work with it, just driving from one place to another in middle range. If working it, I'm at 2400-2500. If you want to keep the rpm's down and keep from lugging the engine, use low range on the HST. Mine had one hour on it when delivered and the next day, we had about a 15 inch wet snow fall. It was out moving snow running it at 2400-2500. What a great job it did.
Enjoy the new tractor and don't forget the 50 hour service.
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
Freightliner Fuel Truck (A56436)
Freightliner Fuel...
Pickup Truck (A59230)
