CoyPatton
- Joined
- Aug 10, 2015
- Messages
- 1,647
- Location
- Poplar Bluff, MO
- Tractor
- Yanmar YM2002D with Koyker 110 FEL
My ground is too rocky, and thus too close to ledge rock to drive a ground rod that way, so I do not even try. I dig a trench with my backhoe as deep as I can go, and then put the ground rod in the trench, and then back-fill.
This was a trick an electrician showed me when we were laying a lot of underground cable, and i thought it was a much better way to "drive" ground rods in the ground.
I am not sure what other electricians think of it, but I see no reason why it is not a good way to do it.
Don’t forget that you can rent a walk behind trencher and avoid a lot of digging. Trench a route for conduit from main panel to sub panel and for ground rods while while you have it rented.
![IMG_20200531_151339401[1].jpg IMG_20200531_151339401[1].jpg](https://www.tractorbynet.com/forums/data/attachments/561/561675-c910a8514818a7cb70ca911c8b268237.jpg)
