Echo vs Husqvarna
/ Echo vs Husqvarna
Need some help-my husqvarna 345 has two nipples, a white and orange, on the fuel tank. Which one goes to the primer bulb? The white nipple is a little bigger than orange. Is one a vent?
/ Echo vs Husqvarna #262
LOL, you are not good for the economy, don't U know that all those newfangled gadgets is what keeps the GNP going.
LOL, what's wrong with the old fashioned methods.
What next?
A computer controlled laser saw mounted firewood measuring device?
Perhaps it'll let U know when each cord is up to specs.
Heck. I simply eyeball and go to it.
OK, sometimes I'm off an inch or so either way but as long as they fit into my stove I'm OK.
Gee Piloon yor really are backwards!! :) Haven't you heard about an app that can be downloaded on your Smart Phone so that you can saw logs while watching TV?! :irked:
/ Echo vs Husqvarna #264
LOL, most times watching TV I do saw logs, especially after dinner and more so during the many commercials the seem to outnumber the actual program.
/ Echo vs Husqvarna #265
Yes, it does. Yet I prefer to burn that length.
I have a retired forester friend he once told me 12 inch is the optimal length for a wood stove to get maximum heating value. He said any more than that and you are just wasting.
Anyone else ever hear that?
/ Echo vs Husqvarna #266
For me it’s the way that they fit into my firebox. 12” can go in end wise; anything bigger has to go in parallel to the door. The ashes and coals end up falling against the door, I end up with hot coals falling out and an unnecessary mess on the fire pad.
/ Echo vs Husqvarna #267
I heard max heat is at 14-3/4"..............
/ Echo vs Husqvarna #268
I heard it was 18 inches. :p
/ Echo vs Husqvarna #269
My outdoor boiler says 38" un-split is the best and 24" comes in 2nd.
/ Echo vs Husqvarna #270
I heard that it was 32 centimeters+ 44 millimeters. :D
Actually. I believe that the dryness of the wood efficiency of the stove and to a lesser degree how finely you split it that effects how well it burns.
/ Echo vs Husqvarna #272
That’s what she said
/ Echo vs Husqvarna #273
I used my small saws today for the first time in about 6 months. The Echo (500P) started in 3 pulls, like it had never been put away. The Husky (562XP) took over 20 pulls, and I darn near gave up on it. It ran and started fine the rest of the day, but geez, I darn near busted my gut getting it out of hibernation. Funny thing is, out of the two saws, the Husky has a primer bulb and the Echo does not.
/ Echo vs Husqvarna #274
You must have flooded it.
/ Echo vs Husqvarna #275
I suspected that as well, but pulled off the air filter to check out the carb and there was no gas smell like I would have expected if it was flooded. I have heard of flakey problems like this with the Autotune saws when stored off season, and I suspect it was one of those issues.
/ Echo vs Husqvarna #276
I have the Echo 501p and the 550xp, both less then a year old, so far the Echo starts the easiest, but my new 550xp starts lot better then the 2013 550xp I had. That flooded on just 1 pull, 3 pulls gas would run out of the exhaust, didn't have to be a Sherlock Holmes to detect, hey I think my saw is flooded. And the fastest way to start it was take the plug out, crank it dozen times, put plug back in and then it would start right up, it was an excellent saw to warm you up in the middle of winter, I'm glad it broke..............
/ Echo vs Husqvarna #277
Funny, my 545 ((same as your 550, but not an XP) was the same way. It would stall 4 times while limbing one tree, and every time I would have to set the brake, hold the throttle and drop start it repeatedly as I mentioned previously. Like you say it really didn’t break my heart the day that I rolled a log on it.
2022 EZ-GO ELITE...
(2) 15 Gal Sprayers, 25 Gal Sprayer, Honda Pressure Washer, Wheel Barrel (A64119)
(2) 15 Gal...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
2015 MGS GODWIN CD150M PORTABLE DRI-PRIME (A63276)
2015 MGS GODWIN...
Trimble 2050 Display Screen (A64119)
Trimble 2050...
Abaco Machines DVL500 Vacuum Lifter (A61573)
Abaco Machines...
