dynamark lawn tractor
/ dynamark lawn tractor #1
justin5890
dynamark
im trying to make a steel snow plow for my tractor any ideas
/ dynamark lawn tractor #4
I used angle iron and sheet metal for mine and it can plow 10 to 15cm of heavy snow
/ dynamark lawn tractor #5
You might want to look around on Craig's list for an atv or lawn tractor plow. Then just build the frame to mount it. I did that with my cub cadet. The curved plow blade helps to roll the snow. Based on Vermont Craig's list for $100 or less you find something.
/ dynamark lawn tractor #6
It pushes snow pretty good and im only 15 and im trying not to spend any money on this project.
/ dynamark lawn tractor #7
I made a blade for my old lawn tractor out of a old hot water heater, shell, jsut cut to lenght and cut the section I wanted it was pre curved, and welded on a wear edge,
/ dynamark lawn tractor #9
A friend of mine said to do that but i had trouble finding a hot water tank
I have one that you are more than welcome to pick up.
/ dynamark lawn tractor #11
talk to a plumber, he probly changes out 3 or 4 min a week, or a scrap yard,
/ dynamark lawn tractor #12
X2 I built on like that for a 14 HP garden tractor many years ago and it worked pretty well. Check out plumbing contractors, or heating and cooling contractors and even the city dumps. I didn't put a rear bar on it at all. You just will need a welder to make a hitch somehow. Good luck.
Whoops, I didn't see the last post.
Snap-On Southern Thunder Edition 24-drawer tool box (A63118)
Snap-On Southern...
EZ Trail 3400 Seed Tender Wagon (A64047)
EZ Trail 3400 Seed...
2017 CATERPILLAR 980M WHEEL LOADER (A64279)
2017 CATERPILLAR...
2015 GENIE S-65 MAN LIFT (A63569)
2015 GENIE S-65...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
Towable Generator (A60352)
Towable Generator...
