dynamark lawn tractor
/ dynamark lawn tractor #1
justin5890
dynamark
im trying to make a steel snow plow for my tractor any ideas
/ dynamark lawn tractor #4
I used angle iron and sheet metal for mine and it can plow 10 to 15cm of heavy snow
/ dynamark lawn tractor #5
You might want to look around on Craig's list for an atv or lawn tractor plow. Then just build the frame to mount it. I did that with my cub cadet. The curved plow blade helps to roll the snow. Based on Vermont Craig's list for $100 or less you find something.
/ dynamark lawn tractor #6
It pushes snow pretty good and im only 15 and im trying not to spend any money on this project.
/ dynamark lawn tractor #7
I made a blade for my old lawn tractor out of a old hot water heater, shell, jsut cut to lenght and cut the section I wanted it was pre curved, and welded on a wear edge,
/ dynamark lawn tractor #9
A friend of mine said to do that but i had trouble finding a hot water tank
I have one that you are more than welcome to pick up.
/ dynamark lawn tractor #11
talk to a plumber, he probly changes out 3 or 4 min a week, or a scrap yard,
/ dynamark lawn tractor #12
X2 I built on like that for a 14 HP garden tractor many years ago and it worked pretty well. Check out plumbing contractors, or heating and cooling contractors and even the city dumps. I didn't put a rear bar on it at all. You just will need a welder to make a hitch somehow. Good luck.
Whoops, I didn't see the last post.
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
2008 CATERPILLAR TL642 6600 LBS TELESCOPIC FORKLIFT (A64047)
2008 CATERPILLAR...
ATS ME18 Mini Excavator (A64047)
ATS ME18 Mini...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2021 John Deere 1023E Tractor Loader (A63116)
2021 John Deere...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
