Dump Trailer Question
/ Dump Trailer Question #1
RedStuff
Connecticut
Branson TYM 5520C
I was looking to buy a new dump trailer and I was wondering if anyone could tell me if there are significant differences in trailering behavior between a deckover or a low profile. I like the idea of a deckover with fold-down sides, but I'm concerned that the higher center of gravity is more likely to cause a sway condition. Any thoughts are appreciated.
I've narrowed my choice down to these two models.
PJ Trailers - 96" Deckover Dump
PJ Trailers - 83" Tandem Axle Dump
/ Dump Trailer Question #2
I don't really think you would notice a difference in towing either one of these trailers.
/ Dump Trailer Question #4
OK, any disadvantages to the low profile?
I just put a deposit on a low profile dump, and I chose it for two reasons:
1. I am going to use it both for a general purpose trailer and a dump (I don't want to spend the money on both). Less wind resistance and better mileage on longer hauls.
2. At a construction site we are going to load it by hand most of the time. Lower deck = easier to load.
Is there any disadvantage to the lower profile? I am pretty certain I could get the deposit switched to a standard height if I wanted to.
/ Dump Trailer Question #5
dump trailers like dump trucks tow very tall.
loaded heavy, they are not a lot of fun.
I'd go for the low profile if I could
how often are you really going to use the side gates?
You can load your one pallet of stuff in the back anyway (two if you push it and then drag the back one out to the end with a chain)
lower is better.
/ Dump Trailer Question #6
Your correct about the HCOG on the deck over. I've got the low pro your looking at. I've been real happy with it. I wouldn't own a deck over unit if it was free. My neighbor whose a roofing contractor had the deck over. And since there real easy to overload he did. Well he went on the interstate in windy overloaded conditions and it began to sway and ended up tipping over and taking the truck off the road. Low pro all the way!!!
Matt;)
/ Dump Trailer Question #7
I rented a low profile dump trailer once. It towed fine, but dumping compost and sand was harder then dumping gravel. When I raised trailer the almost all the way up, the rear of it hit the ground. If I ever get the money, I want a deckover. How much higher do they ride? JC
The only disadvantages to a low profile that I know of are:
1. If you're backing it into tight spots often, you'll ding up the fenders pretty regularly.
2. Like RollTideRam said, sometimes there isn't much ground clearance when at full dump height.
3. The bed of the trailer isn't as wide. (not really a problem, but could be for some)
/ Dump Trailer Question #9
I looked up Bri Mar trailers and their specs show the deck over trailer has a deck hight of 34" and the low profile was 27". On their deck overs you can get fold down sides, so this would actually be a lower deck to hand load. I currently want a Homesteader deck over, but their site does not give many specs. JC
/ Dump Trailer Question #10
They are both tounge drawn trailers, They will require weight distribution to keep truck & trailer level (steering & braking) and anti sway to keep it between the lines. If you don't use these devices it can and will get very interesting.
GN is best when going heavy ....IMOP.
/ Dump Trailer Question #11
I pull my buddies 14K Bri Mar without WD and its just fine behind my F-350 loaded to the max. It may drop the truck 3" but its less than what the boat in the avatar does. I would guess the dump trailer loaded properly has about 1500# of tongue weight.
Chris
/ Dump Trailer Question #12
Well Diamond you pull trailers of all configurations a little more regularly than your average TBN guy and you shouldn't have a problem with 14k behind a dually because of the experience you have with towing heavy loads.
/ Dump Trailer Question #13
Yes, that may be true but I will never pull a trailer that is unsafe again. I pulled a heavy trailer with too little tongue weight and that was horrible. By the way my F-350 is not a dually, its a SRW Short Bed 4x4 Extended Cab Diesel.
Chris
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
HLA Attachments Loader Forks (A64119)
HLA Attachments...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
