Drawbar pull capability
/ Drawbar pull capability #21
This is an interesting little video on the Nebraska Test. We just need one of our members to build what they have and we can all meet there for testing. :ROFLMAO:
/ Drawbar pull capability #22
The test data is useless unless you "hook" to the tractor in the IDENTICAL method.
I can easily change the measured pull of a tractor by 50%,, or more.
That is why the tractor pullers have a requirement for a standardized hitch.
My nephew pulled the front axle out from under a F800 Ford dump truck back in the 1970's
He had the tractor connected to the chain at the top of the quick attach,,
and
he was parked on asphalt.
The front tires were loaded, and there were 2,000 pounds of front end weights on the tractor.
As he started to pull, in low gear, he lifted the 3PH,, the weight shifted onto the tractor,, OOPS!! o_O
Yes, they had the quick attach hitch in the 1970's,,
It looked, and worked identical to the one that HF sells,,
BUT,, it was a LITTLE stouter!! :ROFLMAO:
and
I didn't know you could change the points of attachment on a drawbar except a little swing to the left or right and between the closer or outter hole in the bar itself in some models. What kind of tractor do you have that has verticle adjustments on the draw bar? I've seen older tractors with a "draw bar" attached to the 3pt hitch.... Is that what you thought of when I said drawbar in the initial post?
And though I said draw bar in the initial post, I didn't say tree until a latter post. So drawbar to tree is what it needs to be.
And again.... Instructions would come with the gauge.
/ Drawbar pull capability #24
That's true. Tie to a big tree and pull in a gear available in most tractors like 4H
If they're giving the result in HP, I assume the pull test is being done on a moving load, not a fixed load? Horsepower is a product of both speed and force.
Put otherwise, ignoring traction, a 30 hp tractor can pull awful hard in low gear. Maintaining that pull at an acceptable speed, compared to a 60 hp machine, is the limiting factor.
/ Drawbar pull capability #26
Seems like a waste of time to me, but then wasting time on superfluous things are the norm on here anyway. JMO.
Pot calling the kettle black, 5030! The very act of sitting down to read or type on this forum could be called a waste of time, especially when you're posting on threads like "Will the UAW strike?". We are all guilty! :D
/ Drawbar pull capability #27
I don't make it a career however. Still on strike btw and I see no end to it as well.
I only post comments on 2 forums, this one and a firearms related forum that actually has a politics related sub forum and believe me, it's quite a lively sub forum. Tractors and firearms for me.
I've only seen raw bar hp on large tractors. Never seen it on the smaller ones, which means there's a space for data to be collected.
For instance, I've never seen a drawbar hp rating on my M9960 nor on my B7500. Thus, I think it's a worthwhile endeavor to find out the pulling force of these "small" tractors.
That data can also be used to help a lot of people in their purchasing decision and drive more traffic to TBN, despite the efforts of certain people consistently peeing in other cheerios and driving people off.
/ Drawbar pull capability #30
At some point, they have tested just about EVERY size tractor,,
Don't get critical,, they may have testes a b7100, not your B7500
Or it may be a Satoh that had the same HP, and machine weight.
If you look at the Neb tests,, there is almost no difference in results, as long as the machine is similar.
An Allis Chalmers HD 10 pulls very similar to the CAT machine that puts out 100HP,,
You can not beat the laws of physics,,
The tests are actually boring comparing "pull"
you can pull 60 to 75% of the machine weight,, with tires
The CAT D8, D9,, etc can approach 100%, because the tracks act like the machine is "geared" to the track.
The real purpose of the NEB tests is data like HP-HOURS per gallon of fuel.
Tractor buyers did not want to purchase a tractor only to find out it consumed 2X as much fuel as the other color tractor.
Fuel was a major expense,,
The JD 820 (and 830) around 1958 had far superior results in that test evaluation.
Those machines stayed at the top probably until turbos started being used.
OH, they could PULL,, too!!
/ Drawbar pull capability #31
I think as long as any tractor you "test" has enough hp to spin the tires, that is going to be where your pulling force gets limited out.
And the most important factors there are going to be tire size and type, 2wd vs. 4wd, ground (soil) type, and tractor weight.
Transmission type will be irrelevant (for draw bar pulling) because even an HST will spin the tires, same as a gear tractor. Regardless of what the "chest thumpers" say about gear tractors, in this particular case (pulling) you will be traction limited.
/ Drawbar pull capability #32
Keep in mind that a lot of tractor pulling work is done on higher ranges that just low range.
The fact that the HST spins tires in low range tells nothing when they barely pull their own weight in high range on the slightest of hills.
/ Drawbar pull capability #33
That is true, but even my little 37 hp engine and HST trans will spin the tires in medium range in 4wd. And mine is certainly not a "big pulling" kind of tractor. And if we're after maximum pulling power above all else (including ground speed) then you're certainly not going to achieve maximum pulling power with your gear tractor in a high gear. A 7000 lb tractor with 4wd and industrial tires (mine) will only pull 'x' amount, regardless of which transmission type it has.
Only thing gears get you is less parasitic loss through the pto. And yes, that is well established. But we're talking about straight pulling power only. All the transmission has to do is deliver the torque to the rear end. If there is enough torque output from the engine to overcome traction, you are "done" and have the same result. Regardless of trans type.
/ Drawbar pull capability #35
I think it would tell you that "pull tests" are useless and arbitrary.
/ Drawbar pull capability #36
Others countries still use compact tractors for commercial work and you’ll find a better offering of gear transmissions there. Americans don’t use compact tractors for farming or basically any other task in wide spread use where putting the most of your hp to the ground really matters. The convinces of HST far outweighs a slight hp loss. The only real reason Americans still buy geared compact tractors is for cost savings. As a result of cost savings the vast majority of compact tractors have a crude dry clutch and a basic gear box.A HST compact sized tractor will outperform gears in every aspect except pulling a ground engagement implement across a field. And Americans might use their compact tractor to plow their garden for an hour per year but compact tractors aren’t out plowing 100s or really even 1 acre. Compact tractors aren’t on the roadways either. Occasionally people drive them on the road for the sole purpose of moving the tractor itself but nobody pulls heavy trailers on a routine bases with small tractors here.
/ Drawbar pull capability #37
I believe they are an excellent measure of pulling power IF they are conducted properly
/ Drawbar pull capability #38
As fun as testing this kind of thing would be in theory, it has no practical use or meaning.
A 4wd tractor with R1 tires and 4000lb 50hp dont care if its painted red, blue, green or orange. They are gonna pull the same amount.
Two parts of "pulling" is drawbar power, and max pulling force.
As mentioned, for max pull, a wheeled machine can usually be around 70% machine weight. TRACTION is the limiting factor. And with different soil conditions (moist, wet, mud, loose, dry packed, asphalt, etc) and different tires.....way too many variables. So what if someone across the country tests a tractor that can max pull 4000lbs......and you have the exact same tractor and want to pull a log that only requires 3500lbf and you cant move it because you spin. Maybe the ground is uneven, or slight grade, etc. Its not a real useful piece of information. And pretty much ALL tractors have a gear or range low enough to spin the tires. meaning power is never the problem....only traction.
Now drawbar HP.....that can come into play trying to pull something at speed. Alot of tillage equipment dont work well at slower speeds. They like 4-5mph to properly turn soil. So you may have a tractor capable of pulling a given size disc or plow....but simply lacks the power to do it at speed.
This topic comes up alot when people are questioning/comparing a couple of machines....that are the same basic machine but different HP ratings. Like a deere 5055 vs 5075.....or a 'bota MX5400 vs Mx6000, or any one of a dozen other examples I could cite. Too many times people say you will only notice the extra power if you are using the PTO heavy, and that if you are working ground engaging implements that its the weight and you wont notice the power. But that isnt always the case....if you are trying to maintain a certain speed.
Correct. Some old heavy iron @30hp could probably pull a 3-14 plow. but it would be at a snails pace and not do a good job turning the furrow because it simply lacks the power to pull the plow at a fast enough speed
Most people looking at buying a sub-100hp machine isnt gonna care about drawbar HP or max pull. Because they are buying a machine as a general purpose machine or a utility machine. And quite simply.....more engine HP, and more PTO HP....usually means more drawbar HP. And a heavier machine means more max pull. And since all those stats are well published....and there arent any variables to machine weight and PTO power.....its a better baseline for comparison than some arbitrary data collected where ground conditions, tire type, etc all come into play. So compiling a chart as you propose.....while bein fun, would only serve as a comparison tool and not accurate data. And as mentioned, weight and PTO power already serve as a way to accurately compare what tractor is gonna be a better "puller"
/ Drawbar pull capability #39
Tires, weight, weight distribution. That’s why you can see pickups pulling tractors. My SVL75-2 will pull great on concrete, but will slide backward down my tilt trailer if it’s damp. Driver for my nephew said don’t bother replacing the rim-guard in the Kubota M105S when a tire failed, but now he rarely comes to work because the tractor has no traction.
/ Drawbar pull capability #40
Some people will just never grasp the basic physics of power versus force.
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
(4) ASSORTED TIRES (A62613)
(4) ASSORTED TIRES...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
