Drawbar pull capability
/ Drawbar pull capability #61
Weight was mentioned in post 12, 30, 31, 34 and 39. So seems to me a lot of people already recognized it.
Merely 'mentioning' weight as one of the factors in a broad discussion that also mentions every other variable is hardly the same as recognizing that it is *the* determinant, at least when comparing equal rear wheel HP under standardized soil conditions. The post I referenced was the first to do precisely that.
/ Drawbar pull capability #62
Because it is not the determinate factor, there are multiple factors that will apply.
/ Drawbar pull capability #63
It is not. Again, drawbar is typically given in horsepower (power), not pounds (force). This has already been discussed in several prior posts in this thread.
Measuring the pulling power rather than simple force, allows the collection of data in higher gears, where available torque cannot simply overcome friction/weight, while also providing a more useful measure of the true work a machine can do. After all, gear a lawn tractor low enough and put enough weight on the thing, and it will pull the world... in pounds force.
People have been doing this for years, and these problems have been worked out many times before. Do you honestly believe your first glance at the subject is somehow more informed than practices that have developed over decades?
/ Drawbar pull capability #64
I disagree. Once you recognize that "horsepower" *is* the measure potential pulling power, the only remaining variable is the ability to put that power to the ground, i.e., traction. And traction is simply the co-efficient of friction (soil condition and tire construction) x mass (weight delivered to the soil).
/ Drawbar pull capability #65
I disagree. Once you recognize that "horsepower" *is* the measure potential pulling power, the only remaining variable is the ability to put that power to the ground, i.e., traction. And traction is simply the co-efficient of friction (soil condition) x mass (weight delivered to the soil).
Yes... power. But again, pull in a higher gear. You will measure higher pulling power, both due to elimination of tire slippage and due to reduced gearing losses through the drivetrain.
Think of the tractor pull sled, not a tractor tied to an immovable tree stump.
/ Drawbar pull capability #66
that simple little co-efficient of friction has a 1000 variables, and the mass is not a simple number either a lot of varibles in there depending upon how the weight is biased front to rear and high or low, for just a couple and there are hundreds more.
/ Drawbar pull capability #67
Think about neither for a moment. Rather, consider pulling on a scale attached to the draw bar which records peak pulling power. Yes, gearing and wheel diameter can be used to multiply the engine torque delivered to the rear wheels, but at a lower speed. Nonetheless, the measure of rear wheel horsepower remains the same (force x distance/time). Against the infinite scale, at some point the tractor's rear tires will break lose, or the engine will stall. That is the point of peak pulling power of that tractor. Adding rear wheel weight may increase the motive force up to the point of stall, decreasing weight may increase motive force by preventing stall. In either case, weight is the determinant.
Another commentator earlier posted a very informative, and scholarly exposition on the topic. Unfortunately, it appears that he decided to delete it.
/ Drawbar pull capability #68
Ultimately all those factors boil down to co-efficient of friction between the tire and the earth (here soil conditions, tire construction, etc.), and the weight presented to the ground by the tire's surface, however it gets there (ladder bars on a drag car, or wheel weights on a tractor). Of course, if you want any sort of meaningful comparison between tractors, the soil part of the equation must be held constant.
/ Drawbar pull capability #69
Speculation is a great way to learn basics. It's fun, too.
I used to wonder if our old 90 hp farm truck would outpull the old JD tractor getting a trailer out of the mud..
For a deeper understanding, the Nebraska Tractor test procedures are worth reading. They've been beating on the subject for a long time.
Among other variables, their pull testing procedures measure: peak and constant HP, pulling speed, tire slippage, and fuel temperature.
/ Drawbar pull capability #71
/ Drawbar pull capability #72
Granted, if the sort of comparison you're after is of the 'my tractor will pull more than your tractor' variety, then the all the factors you mention, and many more, will have an impact on who wins. I guess my understanding of the OP's comment seemed to presume something more akin to a standardized testing scenario, where factors like fuel temp, pulling speed (from rest), tire design, etc., would be consistent among the test candidates.
I assume by 'peak and constant' HP in this context, they also perform a sort of endurance test, in other words, loaded pull over distance vs. a maximum pull effort. That also seems like a different sort of testing scenario than what was implied by the OP.
/ Drawbar pull capability #73
my Rhino manual actually lists a version of it for the 504
Traction Force ( with adhesion coefficient being .84 and slip 15%) 17640 (N) Newtons so ~4000 lb force
/ Drawbar pull capability #74
Then it could be a turbo charged super charger engine.
First time I'd ever heard of a supercharger was when reading the box for a Revell P-38 Lightning my dad built for me when I was about age 5. It was called a turbo-supercharger. Obviously it just means a forced induction device that uses a turbine to drive a compressor, instead of a PTO running a scroll or vane type displacement pump. They all "supercharge" the engine.
/ Drawbar pull capability #75
In the early days I think you are right.
More Recently I would say that the generic term "Supercharged" has been replaced by
Forced Induction, Blown, or Boosted as a generic term.
imo, When supercharged is mentioned on most sites it is taken to mean belt driven off of the crankshaft.
Turbocharged would be exhaust driven. At least when cars are involved.
/ Drawbar pull capability #76
The two-stroke detroits have all been gear driven super chargers, they were the super chargers first adapted to automotive engines. Then some of them had turbo-chargers feeding the super chargers.
/ Drawbar pull capability #77
New a guy who had one in a bus. Sure sounded different than say a Cummins with a Turbo.
I missed out on buying a good running MFWD Oliver with one, even had a FEL. Don't need it but sure would be a "neat" tractor to have.
I was thinking about Robert "Paxton" McCulloch as well, he tooled up and offered supercharger kits for the "New" Ford Flat head V8's in 1937 Now that is Hot rodding a High Performance stocker in the early days.
First start of a Ford flathead in many years, sporting a McCulloch supercharger
/ Drawbar pull capability #78
I went to a farm tractor pull in Salem/Brooks Oregon a couple of months ago. An old army jeep tried to do it. It just didn't have the weight or gearing to compete against the tractors, and I don't think it even got started with moving the sled.
So, you have many things to consider including weight, traction, HP, and gearing.
A year or so my mother got the idea to replace her 25 year old John Deere tractor (regular small farm tractor) with a tiny Kubota (sorry I don't have the exact models). My brother got the Deere, so it wasn't lost, but I was very surprised about the shrinkage.
We've tried to pull up a couple of posts with the mini-Kubota. It does really poorly. No power, and no lift.
The last post, we gave up and hooked the chain to my RAM 1500. It pulled the post like it was nothing, despite just lateral pulling and no lifting. The pickup probably has 10x the HP as the Kubota, but also a lot more weight.
/ Drawbar pull capability #79
"Supercharger" is a generic term that includes both belt driven Roots-type and exhaust driven turbochargers.
I have never heard the term supercharger used as a generic term that includes turbochargers as well.
And a turbo charger blowing up is not a common thing at a tractor pull that would make one question the visor being up on the driver. Now throwing a rod, or blowing the head off is another story. Or if it was a IHRA/NHRA track and an "actual" supercharger....thats a different story. Cause it is common for them to blow off the engine.
Agree to disagree. But the context of this thread is about taking drawbar pull readings from different members all over the country, with different tractors, tires, and soil conditions. So no, in the context of this thread, weight is not "the" determinant factor....because equal RWHP and standardized soil conditions are not a factor here.
2010 Brenner Aluminum 407 T/A Chemical Tanker Trailer (A68183)
2010 Brenner...
STORAGE CONTAINER FULL OF HEATER DUCTS (A68842)
STORAGE CONTAINER...
CAT D9H 4BBL Multishank Ripper (A68134)
CAT D9H 4BBL...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2016 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2016 FREIGHTLINER...
PORTA POTTY (A68842)
