Drawbar pull capability
/ Drawbar pull capability #1
Atypical_decorum
NYC
Ultra-Wide B7500 & looking for a 100hp
Has anyone hooked up a pull gauge to their drawbar to find out the actual pull?
A TBN owned pull scale sent out to trusted people and tested in a standardized way would make a pretty neat spreadsheet on here for future generations.
/ Drawbar pull capability #2
IMO, probably the most important measure of power.
/ Drawbar pull capability #3
/ Drawbar pull capability #4
I always compare drawbar power when making tractor buying decisions.
/ Drawbar pull capability #6
Hard to standardize the dirt in different places. But if the same model tractor was tested in many places and soil types, that would be really good information.
Bruce
/ Drawbar pull capability #7
Farm tractors, too. Here’s my Magnum.
Another good measure of power is in the “tests” section of Tractor Data is “Max Pull”.
Bruce
Agreed to both points. A description of dirt could accompany each measurement.
/ Drawbar pull capability #10
What is it you are looking to pull?
Pulling a plow at 1 mph is different than wanting to pull the same plow at 10 mph.
It'd be pulls in each gear of your tractor.
/ Drawbar pull capability #12
To many variables for this to be real accurate if used by random people under random conditions. Would be interesting to see the various results though.
Some of the variables are:
Type of Tires: turf, R4, R1
tread left on tires
Bar or lug angle 23, 30, 45 degree etc.
tractor weight,
type of soil,
/ Drawbar pull capability #13
$141k... puts some of our whining about pickup truck pricing in perspective! :D
That was 20 years ago.
They’re $350K-$400K now.
I paid $40k for mine, well used, which is dirt cheap. It was 22 years old. Still makes 250PTO HP.
Magnums are stupid powerful & heavy.
Buy weight just as much as you buy HP/TQ.
tread left on tires
tractor weight,
type of soil,
Yes. That's true. And kinda the point. If you have 10 readings of an L6060, someone looking at an L6060 can say that's close to my setup, I'll get about that much pull given X conditions.
Eventually, there will be enough readings where a good picture of the tractor and various setups will emerge.
/ Drawbar pull capability #16
tread left on tires
tractor weight,
type of soil,
How recently the gauge was calibrated against a known standard.
/ Drawbar pull capability #17
Most of the variables thrown out are traction-limiting factors. But drawbar pull in horsepower could be taken in a higher gear, where traction is not the limiting factor. Again, I suspect this is why it's given in horsepower, rather than pounds force.
Dude. This isn't for weighing diamonds or medicine. A 25k pull gauge that is accurate to about 50-100lbs won't run out of spec so fast as to invalidate results. Even if there were drift that caused the scale to have +/- 100lbs, it wouldn't make much difference in a 5k lb pull for this purpose.
That's true. Tie to a big tree and pull in a gear available in most tractors like 4H
/ Drawbar pull capability #20
I would think the Nebraska tractor tests are all done on the same grounds?
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
451 New Holland Sickle Bar Mower (A66408)
451 New Holland...
case 370 glass door never installed (A61307)
case 370 glass...
6ft Metal Star (A65583)
6ft Metal Star...
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
213098 (A64276)
213098 (A64276)
