Decompression doing anything?
/ Decompression doing anything? #32
I think depending on what part of the Country we're from,
Some folks refer to "starting" as turning the engine over- via: ( starter ) Some Folks use the term "Cranking"
Others can become confused with either term, I use the term cranking= as cranking the engine over, then the engine starts/runs, But I also know what is meant when refereed to as starting the engine, Turning it over and having it start/run, Oh! and when turning the engine over doesn't necessarily mean turning it upside down, :D
oh! and I am one of the ones who will slightly pull the throttle open ( I mean slightly ) and then open the Decompression and crank over the engine for a several seconds, When I release the decompression lever it starts right up and runs, However I seldom need to do this, only if the battery has set and run down, It certainly helps to take the load off the starter;) and also helps to pre-warms the cylinders, doesn't matter to me if it spits a bit of smoke when it first fires up and runs, what matters to me is that it gets fired up and running...beside Isn't a little smoke the nature of a diesel;)
Oh my! ther's another term can be used ( Fires up ):D
/ Decompression doing anything? #33
How does the combustion chamber warm up when cranked with no compression?
Are these compression release systems affecting all the cylinders or half of them?
/ Decompression doing anything? #34
Friction = Heat- although oil may help to reduce friction/heat, but not all together... some heat still remains even if only "Warm"
We all have cranked over an engine before and it not start, then we try it a 2nd time and it fires off and runs, Maybe the fuel maybe friction that helps heat the cyl. that helped to start it up,
I do know a Piston with good rings will create Friction/Heat in the cylinder walls, the extra amount of heat is created of course at detonation, But none the less there is heat created from friction alone,
Example: pull the spark plug out from a small engine, such as a chain saw, although there would be no way you could pull it over as fast as a electric starter, but 5 or 6 quick pulls and stick your finger in the hole, It will be warm,;)
answer to the second- would be all cylinders are relieved of compression, otherwise if one cyl. still had compression you would note it when on the compression stroke,
/ Decompression doing anything? #35
It will NOT start in decomp. if functioning properly.
Mine sure did. There is a difference indeed between not pulling the decomp and pulling it. It takes a little longer to start when the cable knob is normally in the pushed in position. The pull out allows to start eaier, but need to be pushed in right after a start. It' s sort of like a choke.
/ Decompression doing anything? #36
I would like to see a tractor with a properly adjust and 100% functional decompression system. And what the operator's manual says.
If every cylinder is truly decompressed and stays de-compressed. There is no way that engine will start.
/ Decompression doing anything? #37
Can't happen. Your decomp needs adjusting.
/ Decompression doing anything? #38
Mine sure is happening like that. It will start, but will not run long in that decompression pulled state. Just like the other poster said, chug chug chug wroooom it starts normally. With the decompression pulled it's like wa wa waaa waaaa starts and putters a bunch until the decompression cable is pushed back in. My tractor is a total refurb from the ground up recently from Fredricks Equipment. It's a new cable with all new hardware to the valve cover and linkages.
/ Decompression doing anything? #39
Well I doubt Fredrick's is infallible and though no diesel expert (my father WAS so some rubbed off) I do know that if the compression is truly relieved the engine can't start. However, my 3110 WILL start with the relief in the rearward position which means that either 1) I am not operating it properly or 2) It isn't truly relieving compression. I happened to service my tractor yesterday and while looking through the engine oil fill hole I operated the compression relief. Though I can see the shaft moving, it doesn't look like it is attached to anything. Sure would love to know how the thing works, and what the procedure for adjusting it is.
As a side note the placement of that thing is a really poor design decision. It interferes with my funnel when filling the tractor with oil. Had to get my wife to hold the funnel while I lifted that 2 gallon jug of Rotella. All basic maintenance operations should require no more than 2 hands in my opinion. Guess they figured you be filling with quarts or one of those handy pumps like they have @ Jiffy-Lube. :)
Dallas
/ Decompression doing anything? #40
Dallas
also some of the fluid fill holes can be in places awkward to get a bottle/jug into, I realized this when first flushing the hydraulics of my tractor, attempting to hold a 5 gallon bucket over a hole in an area it wouldn't fit wasn't going to happen, I quickly realized I had to first transfer the oil from the 5-gal bucket into a 1-gal jug, and of course by using a funnel that it would filled faster than would drain would become top heavy and tip over,:cool: what a mess that was, :eek: if ever you change the hydraulic oil definitely get yourself a transfer pump,:thumbsup:
I do have one now, and quite handy for many uses :D
2025 Swict 72in. Skid Steer Bucket (A59228)
2025 Swict 72in...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2017 Toro Sand Pro 5040 Bunker Rake (A59228)
2017 Toro Sand Pro...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
John Deere XUV825E (A61307)
John Deere XUV825E...
