Ym2000 engine problems
/ Ym2000 engine problems #1
ryan77704
ym2000
My Ym2000 just started acting up. I bought it about a 5 months ago and changed all the filters and fluids. I was idling the other day while off the tractor unloading some stuff and it started running very rough/loud. I immediately decompressed it to shut it down and tried cranking a little while later after checking to make sure it wasn't hot or anything (I have a gauge for water temp I installed). I tried cranking the engine for a while to no avail. Eventually the tractor fired briefly and died. After this the motor would not even try and start but the solenoid for the starter was engaging it sounded like. I got another starter and charged the battery to full and found that it still would not try and turn over. After several trys, it broke free and tried to crank. The engine again fired and died immediately after and would not crank again. This is with the decompression lever all the way to the left so the flywheel should free spool. I did find that the far injector line was stopped up and I cleaned it out. Could the problem be the injector itself? I'm hoping its not the engine seized and something more like air lock or something but I'm clearly not an experienced diesel mechanic. Any thoughts on what this could be?
/ Ym2000 engine problems #2
I don't understand how an injector line could be stopped up. Are you talking about the steel line from the injector pump to the injector being stopped up? If I am understanding correctly you are saying the engine will not turn over now with a new starter and good battery? Confirmation on that?
Yes, the steel line where it goes into the injector was not putting out any diesel when turning the key while it was actually trying to crank. I cleaned the line and it began putting out the same amount as the steel line into the other injector (had them both removed). Yes, the motor will not turn over with new starter and good battery. Solenoid of starter engages and hums, but no crank.
/ Ym2000 engine problems #4
That region should always be spotless, which ordinarily would lead me to suspect that you might have a fuel issue causing filtration failure, and gunk downstream. However, that would not explain why you couldn't turn the engine over with just the starter. That makes me worry that something else is going on. A new starter just humming is usually a sign of a bad cable, or a bad cable crimp, (check or replace and clean all the hots and the grounds) or a bad solenoid, or a sign that there is a mechanical issue.
I would pull your injectors, and see how they look. I would also check your fuel lines to make sure that you don't have an old fuel line that is either leaking, or leaking air, or debris. I would also try turning the engine over by hand with the injectors out to see if the there is something mechanically amiss. If that all checks out, I would check that the decompression lever/linkage is all actually working. If so, I would check to see if the cleaning of the electrical cables, crimps and battery posts helped the starter turn over the engine with the injectors out. If the starter can turn the engine over with the injectors out, I would check that they spray reasonably.
Good luck!
All the best,
Peter
/ Ym2000 engine problems #5
I had the decompression stick on my YM2000!! Not long after buying it. What happened it was dirty with hard corrosion and it held the Decompression Shaft linkage and prevented it from shutting. I pressed down on the linkage were it goes through the Valve cover. It fired right up. Pulled the valve cover off and cleaned it. Never happenened again! Time to replace the Fuel Filter,Bleed the Injector pump and see what happens. May think about pulling the Injectors and Chk. the spray pattern. No location but Napa should have the Fuel Filter #3262 Make sure the Starter gear Is moving. Pull the starter and turn the Ing. key and watch for the Gear movement and engage the fly wheel.
/ Ym2000 engine problems #6
If engine is not turning over then that is the number 1 issue. As Carey said, make sure the starter is good and if so your engine must be locked up. Probably hard to do but you could try turning the engine with a socket and ratchet. I am thinking it is a 46mm socket size.
/ Ym2000 engine problems #7
If one fuel line is clogged, the others are compromised.
Bad fuel or aged old fuel or a dirty fuel tank, lines, filter, bowl and pump can all be affected.
Even with a new fuel filter, a dirty tank of old diesel can foul things up rather quickly for a poor idle. Yanar manuals state not to idle for more than 10mins at a given time. Idling for longer will create too much soot and blackened exhaust of un-burned fuel.
The YM2000 with the 2TR20 engine should run 10W30 or 10W40 diesel summer and 5W30 winter. 15W40 is too heavy or thick. This traps heat in the engine longer. Not a good thing for old Japan made engines spec'ed to JIS standards.
I use to buy off-road diesel as it was cheaper. However, in my area, the off-road fuel wasn't sold frequently enough, so the off-road diesel fuel would gum/gel up sooner. This is bad in the tank for microbes to ruin the fuel. For the few cents I was saving, it costs more in the long run for sooner maintenance. I now only use diesel from very frequent stations and diesel pumps. Fresh is best hands down overall.
Clean the tank. inspect hoses and lines. Purge them. Replace the fuel filter, o-ring, and bowl once again. The fuel pump can be cleaned with Gumout Multi-System cleaner. 1 bottle for about 5-gallons will do the trick. This works better than Seafoam. I've used both with good success, just the Gumout does a superior job.
/ Ym2000 engine problems #8
If the motor is not turning the Eng. The pump will not pump any fuel It's Mechanical. Not Electric.
If it is pumping fuel Clean the Fuel System out. Don't use old Fuel!! that would defeating the purpose. Clean the tank out also. May want to replace the fuel lines for dry rot, Pin holes Etc.. Super cheap to replace.
/ Ym2000 engine problems #9
I think you guys (many anyway) are missing the point. Getting all excited about a (possible?) fuel problem when the engine won't even turn over? In my opinion this engine has bigger problems than a "clogged injector line" and worrying about how to treat the fuel and fuel system is not going to find or solve the real problem. It's deeper than that.
Yes, as Harry in Ky stated, this seems to be a more serious issue much to my dismay. I opened the valve covers to check and make sure the decompression linkage was actuating and it was (as careyo63 suggested). As I said, I recently changed all the fluids. When I researched online before changing the oil, I found multiple places which said that 15w40 was the correct oil weight. So, if bmaverick is correct I have an issue there already. I did not show over 130 degrees F on my temperature gauge during the time that it started running rough/loud though. There aren't many places that work on ym2000 models as they are "grey market" tractors I'm told. As I previously stated, I have not messed with diesel engines much. I am just stuck on the fact that after installing the new starter, it did break free and try and crank after being stuck. Then it fired (not even enough to wind up), died and stuck again. I have not been able to charge the battery again due to weather conditions and the location of the tractor when it went down. I do believe Winston is correct and the motor is seized. Any advice on what to do in this instance? I know Winston said I could try and turn it by hand with a 46MM socket. I am wondering if this would require me to take off the serpentine belt and remove the pulley or if there is a different point I could try and turn the motor from?
/ Ym2000 engine problems #11
The last time I was faced with a similar situation it was a seized rod bearing. It was no surprise since the engine had been run with little or no oil in it. Similar symptoms though. The engine stuck, was VERY hard to turn, but did eventually break loose with enough effort, and it was then able to start with the starter, but didn't run long. As soon as it was shut off it was seized again. The next step was a total rebuild.
If you want to try and break it loose, I wouldn't bother with the "socket on crank" trick. Take the starter back off and use a prybar on the ring gear teeth. If you can't move it that way, you know what's next.
Thanks to everyone for their posts/suggestions. I do believe I'm going to be spending some $$$ on this one.
/ Ym2000 engine problems #13
Turning the crank by hand should be easy once you get the socket on the bolt of the shaft. My have to move fan shroud from what I can recall. Or try to pull the Fan belt at the Fan pulley. All your looking for is the Crank Shaft pulley to move. Mark the pulley so it will be easy to see if it moved. Sounding like it broke a piston ring in a Cylinder. And the other cylinder may have ran and the broken ring Locked it down. Very Normal. Not much to repair if that is the problem. And get the parts!!
/ Ym2000 engine problems #14
And Bye the way JD. sold The Yanmar made YM240 back Yrs. ago. Same Eng. You have on that YM2000. They can Grey it up all they want. It's a Deere.
/ Ym2000 engine problems #16
Pull the injectors out of it.. THAT will bypass any decompression issues..
U could pour some penetrating oil into the cylinders.. either just for lubrication or to break the rings free..
Let it sit.!!!
U can remove the starter and try to get it to move by turning the flywheel..
Good luck
/ Ym2000 engine problems #17
Let it sit.!!!
Good luck
Good point to take.
REM oil, Lucaus oil, 5W20, anything as a good thin oil. This way, the oil can seep around the tight tolerances of the piston rings.
Use it plentiful.
Let it sit for hours 4 to 6. Maybe even repeat this a few times in those hours.
Then as Winston made mention of, rotate the engine by hand with he 46mm or so socket. If the engine is really drenched in oil and will turn with lets of strength, then use a cheater bar to turn the socket. You ma be able to turn the engine carefully on the lowest setting of an impact gun with the socket too. Just pull the trigger slowly. Additionally, when you are doing this, open the decopression to all for the FREE WHEELING of the engine.
The goal is to get the slight corrosion on the surfaces wiped off. So, lots of lite oil is needed.
IF you can get the head off, clean everything there, rotate the engine carefully while it's drenched in lite oil, you could get deep into the cylinder sleeves to clean those out too. This would give you a top end cleaning.
IF you get the head off and it's very clean, chances are the problem is in the bottom end. This makes the cost less for overhaul.
You would need the proper head gasket. After the head is off and all is cleaned, we can guide you on how to get the head back on with new gasket and the torque sequence whick is extremely important. Not hard to do, but very important. I do believe rScotty's last message on this at the YTOG is perfect.
/ Ym2000 engine problems #18
A note on getting the injectors out - Mine on the YM240 had never been out since new. I had a h****** of a time getting them out, using what I had on hand to cobble up a removal tool.
Here's my longwinded post from 2010, with photos, showing the process.
Hoye's diagram of the YM2000/YM240 injector.
You may want to buy Hoye's injector puller.
Added, just for fun. Quoting what I wrote 13 years ago:
According to the Service Manual it should be possible to clean the nozzles if you can find the right materials: "polish the orifice only with a wooden stick lubricated with mutton tallow...". How's that for Old School! I love this tractor. It really is designed for overhaul by the owner if needed, anywhere in the world without benefit of modern technology. They don't build them like that any more.
/ Ym2000 engine problems #19
I'm sure someone else has said it by now. Don't stop your engine with the decompression lever...many have said it's not good, there is a potential for valves to hit. I myself don't see how they would hit at higher RPM yet not hit at low starting RPM? Anyone folks that know more than me said not to so I wouldn't do it.
/ Ym2000 engine problems #20
Don't worry about the oil it is NOT your problem and has zero to do with your issue. Sounds almost like you need a starter rebuild if I understood what I read. Sounds like it's just spinning and the bendix is not jumping out. Well I say rebuild, but it's really just a bad solenoid probably.
(2) COLE FERTILIZER DISTRIBUTORS (A64278)
(2) COLE...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
2026 SDLANCH SDLC1220 High-End Carport (A64194)
2026 SDLANCH...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2010 Mertz Manufacturing 50003-02 T/A Fracturing Pump Trailer (A64194)
2010 Mertz...
