Database Errors Again?
/ Database Errors Again? #1
smstonypoint
Super Member
SC (Upstate) & NC (Piedmont)
NH TN 55, Kubota B2320 & RTV 900, Bad Boy Outlaw ZTR
A month or so ago (maybe longer), TBN suffered problems that affected posting. I think I am seeing symptoms of a similar problem. The system acted strange when I tried to post a reply and I got a "database error" or something similar when I posted. The post did show up in the thread but does not show in the count of "replies" under that thread. I have also noticed that the "replies" count is not updating for other threads I checked.
Is anyone else getting a "database error" message?
Steve
/ Database Errors Again? #2
Steve
Just got one on my last post.
Database error popped up and I was still on the screen where I would type my reply.....like it didnt post. So I went to click repost and got a message that it was a duplicate of a post I recently made.
So while I got the database error, the post apparently posted anyway.
Edit: same thing on this post too
Edit edit: getting database error when editing also
/ Database Errors Again? #3
I'm having the same issue
Also my "New posts" not working
/ Database Errors Again? #5
Yes, I received the error earlier this morning. My post showed up at the end of the thread but the fact that I replied to the thread is not reflected in "Today's Posts" or in my profile or subscribed threads.
/ Database Errors Again? #6
Same down here.
:wrench:
It looks like the problem must have started about 2:00 am.
Steve
/ Database Errors Again? #8
Yea, thats the biggest PITA. Just realized that the new posts I replied to this morning are not in my subscriptions. So now I have to go hunt them down and add manually
/ Database Errors Again? #9
Just tried to post and nothing happened so clicked post button again and it said I already posted. Bug in the system somewhere.
/ Database Errors Again? #10
Just tried to post and nothing happened so clicked post button again and it said I already posted. Bug in the system somewhere. Then tried to post this post and got the "The following errors occurred with your submission - Database Error"
/ Database Errors Again? #11
Had the same issues this AM. Lost two posts.
/ Database Errors Again? #12
Yup, me too. Ditto to all of the above.
Maybe the overnight cleaners unplugged a server from the wall to plug in their vacuum cleaner?
/ Database Errors Again? #13
Same here. Posted some replies. Database error, then appeared to post, now those posts are gone.
/ Database Errors Again? #14
Just had the same here. What I do when it happens is select all and copy my post so I don't loose it then refresh the page to see if it posted. That way I avoid a duplicate post and most of the time the post is there despite the database error message.
I just switched to Chrome to try and do away with other issues which has so far helped. Was having to click back twice to go back and was being redirected several pages in on threads I had never visited. Both seem to have been due to using Firefox.
/ Database Errors Again? #15
Same issue as last time. Something is occasionally hiccuping and breaking one of the tables (the table used to search all the posts.) It doesn't affect the data, but it does affect the ability of the forum to operate smoothly. It's an easy fix, I just take down the database and run a repair. However, TBN has a lot of posts, and it takes close to a full hour to run this check and repair.
It's completed, and I'm going to keep an eye on it for a bit. But things should be okay. Post counts and reply counds might be off on some threads until a new post is made and some other minor issues that should resolve themselves. But I'm going to keep watching to make sure we're running again. If I have to do any more checks or repairs, I will.
Happy Sunday!
Happy Sunday!
Thanks.
Steve
/ Database Errors Again? #17
Will come back in an hour.. see if the problem is cleared up. tks
/ Database Errors Again? #18
Happy Sunday!
Thank you!
/ Database Errors Again? #20
I still can't get to the last pages of some threads.
What worked last time was to reply to the thread in the last page you could view. Once you replied you could then see the last page and go back and forth any page in the thread.
The other option that worked (at least for me) was to open the thread from the app on my phone and that would let me see the last page of the thread.
Aaron Z
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
500 gal Poly Fertilizer Tank (A66408)
500 gal Poly...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
Cedar Boards (A65640)
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A65053)
2019 KOMATSU...
