Try the new tractor database
/ Try the new tractor database
One other issue your AI sorter may or may not have is whether there are spaces, for instance "GC 1723E" versus "GC1723E".
I also don't find this thread: What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY, although it may be linked somewhere.
Just linked it.
The way that system works is with tags. If the thread is tagged with the specific make and model, it will appear in the database page. If not, it won't show. We retroactively tagged tens of thousands of threads but there are 500k threads on the forum. Not all of the 500k are model specific but it's certainly possible that there are still tens of thousands that could be tagged with a specific model.
Tags circled in cyan. Manage tags for a thread circled in red. Right now only moderators can manage tags but I think we need brand moderators at this point to manage tags.
/ Try the new tractor database #23
Just linked it.
Is there a way to TAG those to lets say a tractor brand and the tractor series. I know not all tractor brands use a series, just numbers.
So if a posting deals with tractor weights for a certain series, people can find the info for all those models. Likewise for lights and common gauges.
Maybe the person just creates the tractor series model as YMxxxx or CKxxxx, etc. Not certain here. Need to explore more.
Yes, this is a huge undertaking. :unsure:
/ Try the new tractor database #24
BTW, when the database disappeared, I created this thread on TBN for all of the Yanmar vintage machines in the YM series. Wow, what was I thinking, it was a huge undertaking. Took several months to find data, arrange it all and proof read. Nothing else on the internet has this complete detailed information in one place.
Yanmar - Model Cover Pages
@Muhammad I believe you had once seen this before.
/ Try the new tractor database #25
Once again. (y)
We have a different plan for organizing by series. Brand forums will organize threads by series much in the way you're describing. The database will be specific models.
/ Try the new tractor database #27
If you'd like to be the Yanmar moderator, that would be great. We can discuss more via private message.
Sure drop a PM anytime you have a moment.
/ Try the new tractor database #28
Upon looking at the Yanmar section, there are tractors, wheel-loaders, excavators, field planter machines, Yanmar industrial mining equipment, two-wheel tractors and 1 sail boat. LOL
In a similar way, the Kubota brand has the same undertaking.
There is also the sub-thread for the Yanmar genset and industrial standalone machines too.
Forum for air cooled diesel engines and clones
I have most of the datasheets and/or product logs for all kinds of these machines.
Sail boat, you say? 🤣
The db has more than just tractors in it. But we can definitely remove the totally unrelated items. One good place to start is by looking at what we have threads and reviews for. Perhaps also cutting entire categories, like wheel loaders that aren't part of our typical discussions.
/ Try the new tractor database #30
Wow, I just discovered this thread. What a great idea! Thank you Muhammad for undertaking such an ambitious project.
Will it be possible to go back and add tags to our old relevant posts?
Yes. We will enable that and also provide some instructions on how to accurately tag threads to a specific model.
/ Try the new tractor database #32
We need the mini wheel loaders. They have Yanmar engines and use the same front end loader buckets. These mini wheel loaders are the size of our compact tractors, not the huge size like Forestry. Some farmers use them to scoop up grains too. Yanmar V1, V2, V3, V4 and V5 match the SCUT to CUT sized tractors.
Other brands have skidsteers in the database too. Some farmers use the skidsteers and Toolcats as their farm tractor.
/ Try the new tractor database #33
Could we also tag a thread to multiple models? For example, a BH can fit several models. Likewise a loader. It's all based on the common frame size the OE uses as a platform.
Yes
/ Try the new tractor database #36
Just linked it.
What a wonderfully ambitious project, Muhammad. Congratulations for the undertaking.
Again you are leading with something all forums will want to have someday.
Yes, I see the problems with creating a tagging system that relates the various subject lines - and postings - with specific models.
But hey, at least for tractors we often have bits and pieces of model numbers. Where does something like "Sharpening a drill bit" go? Or "Comparing Tire Types?
I doubt if TBN members are going to voluntarily make their Tractor ID & model description more uniform or specific. And even if they suddenly did so, we still don't want to lose the technical history already existant.
So it looks like the challenge will be to improve on the old-fashioned hand-programmed multiply branched "if/then" program that sorts posts for variations on model numbers, tags them, and dumps them into a repository.
My suspicion is that someday that type of sorting will be trivial for AI, but today getting it operable is still based on human ingenuity. If I think of something useful I'll chime in, but for now will just follow along. watch, and learn.
Thanks again for what you do,
rScotty
rScotty
It's well within the capability of ai right now to read a thread and determine what the topic is about, and within our capability to create the system that does that and tags it correctly. With 500k threads, it's a wonderful application of the technology and so far we've found it to be very accurate.
Where we are at right now is we went through a "first pass" to catch the low-hanging fruits of identifying threads for models by the subject line (thread title) content. The next level will be to read the first post as well and identify if a thread title is "problem with steering" and the thread content identifies the make and model. As others have suggested, there's a bit more to the story when you factor in threads that apply to multiple models, such as with attachments or maintenance topics. To answer the question of where comparing tire types go, that would be, for now, in the forums they are in.
We are more likely going to organize the topics by tag with advancements and improvements to our tag pages. For example, tagging all threads about "grading a driveway" and giving users the ability to sort those tag pages by date posted, number of replies, etc.
/ Try the new tractor database #38
Nice explanation. I see where you are at with it. What a clever challenge you have set up for yourself. I envy you the fun you are having with AI. Thanks for letting us spectators follow along.
/ Try the new tractor database #39
/ Try the new tractor database #40
