Culvert for creek?
/ Culvert for creek?
AgriSupply has the Dual Wall Soil Tight pipe and there is a store in Garner.
Dual Wall, Soil Tight Drainage Pipe, 12 In. x 2 Ft., ADS
However, looking at your stream, you have a lot of twists and turns. This pipe is not flexible so may not be the answer.
The main part of the stream that is diverting is basically straight. Can you suggest something that might work better if I did have to have it installed in parts of the stream that curve or wind?
/ Culvert for creek? #22
You are WAY over thinking this!
What you need is 12" black flexible corrugated culvert pipe.
/ Culvert for creek? #23
Use a backhoe and dig a sloped trench/ditch for the stream bed. Put the plastic down and then line it with crushed stone rocks over the plastic. Slope it with measurements so that it is alway running down hill. It should last forever.
I thought the same, but have zero knowledge on this matter. I think Lowes has 20' x 12" sections for $ 150.....which means maybe a landscaper has it for much less.
/ Culvert for creek? #27
That is just too simple! Cheap, simple, non clog, easy clean!
/ Culvert for creek? #28
Did someone mention Florida Sinkholes??
[video]https://pubs.usgs.gov/of/2000/0294/report.pdf[/video]
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
AUTOMATIC TRANSMISSION / TRANSFER CASE (A68842)
AUTOMATIC...
2008 Kohler 300REOZDD 375kVA Standby Diesel Generator (A66734)
2008 Kohler...
THERM DYNAMICS TD 375 FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
THERM DYNAMICS TD...
2015 CHEVROLET CAPRICE POLICE (A66091)
2015 CHEVROLET...
