Culvert for creek?
/ Culvert for creek? #1
trauts14
high point
john deere
I have a stream that is approx 8" wide and approx 4" deep. The stream is slow moving and is needed to feed water to my pond. A 50' section of this stream has holes in the ground that make the water flow subterranean which reduces the water my pond gets. Would plastic corrugated culvert be the best option to prevent the water from diverting subterranean? I was using think plastic sheeting to line the bed of the stream, but with time deer walked on it and punctured it.
For what it is worth, the stream does get silk buildup over time. I have no idea as how to address this problem.
/ Culvert for creek? #2
Culvert Pipe comes in 20' section and as small as 8". Rural King has some HERE. put your plastic sheeting down and the culvert pipe over that. Wait to see if it does the trick then cover the pipe with dirt.
/ Culvert for creek? #3
I don't personally like messing with how mother nature routes water.
The water that is going underground.....where is it going? What negative effects are going to result if you do this? Big sink holes like seem to be happening more and more frequently?
Thank you. The plastic sheeting we have been using is currently down in the stream. I can leave it down with culvert over it. Out of curiosity, what is the benefit of leaving it down when culvert is over it? Also, will corrugated culvert allow silt to accumulate within the culvert? Thank you for your assistance.
/ Culvert for creek? #5
trauts14
The pipe should only be corrugated on the outside ... smooth on the inside. Although silting can be a problem in a pipe with a very small drop from one end (inlet) to the other (outflow), for 50' it probably won't. My primary concern would be nests during dry spells. The corrugation is to add compression strength. The sheeting, on second thought, may serve no real purpose. I just thought it might be an additional barrier to the water going underground and might have helped in keeping the water from undermining the pipe but it also could do just the opposite.
LD1
Excellent point but the sink holes in the news generally are coming from the community pulling ground water from the aquifer faster than it can be replenished especially in fragile rock formations like sandstone - read Florida. Diverting an 8" wide "stream" IMHO, assuming that this is a rural area with a pond and the neighbors more than 6' from your bedroom window, isn't going to make a lot of difference in the grand scheme of things. But that's just my :twocents: worth. As always I could be wrong.:eek:
/ Culvert for creek? #6
trauts14
LD1
You kind of just made a point...(being from Florida, I can understand).
If water is being pumped out of the ground, and someone removes a source of it going into the ground, isn't that going to offset the balance? A single place that is covered up may not make a difference, but what about that thousands of them that are done, don't they all add up to a little more than "a little"?
Think of the thousands of miles of roads built into lowlands, think of the thousands of houses built on ground that was "filled". That also doesn't include al the extra water being pumped out of the ground.
Just saying, if we can reasonably keep from upsetting the balance, shouldn't we?
David from jax
Thank you for the help. This item would not work since it is corrugated on the inside correct?....Shop ADS 12-in x 2-ft Corrugated Culvert Pipe at Lowes.com
Would home depot, lowes, tractor supply sell the pipe you mention that is smooth on the inside? To be safe, I was thinking use 12" pipe to accommodate a heavier stream after a storm.
/ Culvert for creek? #9
T
Nope. You need to find someone who supplies large landscapers & highway departments. I found a company like that near me when I needed to install a few hundred feet of French drain. The stuff they carried that was the same as Lowes was less than half the price (4" flexible drain). They also carried all of the big stuff that the consumer box stores do not carry.
This is the kind of company you need to look for. To find them, I searched on, "culvert supply Winchester VA"
Try the same in your area, you'll probably find what you need.
/ Culvert for creek? #10
Solid 4" PVC would carry all the water you need and have no corrugation to catch debree for approx. $50.
/ Culvert for creek? #11
I use 20". 20' corrugated pvc culvert for my ditches where I drive over them. Heavy rains and the springtime melt sees the most water with a steady flow. I set my culvert in so that the inlet side ground was slightly higher than the culvert entrance. On the outlet side of the culvert it is close to the same height as the ground or a bit above. I sloped the ground before setting the culvert in to ensure that the water would want to run out - just a couple of inches difference one end to the other. I filled in the culvert and lined stones along the ground on the ends for the water to flow over. Never a problem and I've had 11 yd gravel dump trucks drive over them without any issues.
I would think that culvert size really depends on what is the deepest and widest the water ever gets during the year. An undersized culvert will wash out.
Are you diverting water to your pond or planning to reroute all of the water to your pond. Interesting project.
I buy my culverts from the local hardware store (they can order too) or from the feed store 45 min. away. They have everything in stock, galvanized too. Check out your yellow pages.
/ Culvert for creek? #12
The Lowes link is to "Dual Wall' Pipe which is smooth on the inside. The same pipe I used for my culvert.
You will also need 2 couplings:
Shop ADS 13-in Dia Corrugated Coupling Fitting at Lowes.com
/ Culvert for creek? #13
I would strongly disagree with the suggestion (Billrog) that you use 4" PVC.
The 4" might carry the water that you have, but a twig, with some leaves/debris will completely block it off.
A piece of 12" corrugated culvert pipe would be your best option.
/ Culvert for creek? #15
I found out smooth inside collects less dirt etc, out side tip down little,also if 12" culvert enough I go one size bigger for you never know what mother nature will throw at you.
/ Culvert for creek? #17
Agreed.
the link is for a coupling device. i would like a link to a dual wall if you have one. i had no luck when i searched. thanks for assisting.
/ Culvert for creek? #19
Looks like you got good engineer on the job. :)
Have you consider flash flood or sort?
/ Culvert for creek? #20
2001 FREIGHTLINER FLD132 XL CLASSIC (A67714)
2001 FREIGHTLINER...
2015 DODGE CHARGER CAR (A66091)
2015 DODGE CHARGER...
2013 Volkswagen Passat Sedan (A66738)
2013 Volkswagen...
CRATE OF FLANGES AN PIPING (A67714)
CRATE OF FLANGES...
2019 Honda WDP30XK3AT 3in. Diaphragm Trash Pump (A66734)
2019 Honda...
2009 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2009 INTERNATIONAL...
