Culvert for creek?
/ Culvert for creek?
AgriSupply has the Dual Wall Soil Tight pipe and there is a store in Garner.
Dual Wall, Soil Tight Drainage Pipe, 12 In. x 2 Ft., ADS
However, looking at your stream, you have a lot of twists and turns. This pipe is not flexible so may not be the answer.
The main part of the stream that is diverting is basically straight. Can you suggest something that might work better if I did have to have it installed in parts of the stream that curve or wind?
/ Culvert for creek? #22
You are WAY over thinking this!
What you need is 12" black flexible corrugated culvert pipe.
/ Culvert for creek? #23
Use a backhoe and dig a sloped trench/ditch for the stream bed. Put the plastic down and then line it with crushed stone rocks over the plastic. Slope it with measurements so that it is alway running down hill. It should last forever.
I thought the same, but have zero knowledge on this matter. I think Lowes has 20' x 12" sections for $ 150.....which means maybe a landscaper has it for much less.
/ Culvert for creek? #27
That is just too simple! Cheap, simple, non clog, easy clean!
/ Culvert for creek? #28
Did someone mention Florida Sinkholes??
[video]https://pubs.usgs.gov/of/2000/0294/report.pdf[/video]
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
Concrete Mixer (A62613)
Concrete Mixer...
John Deere 400 Rotary Hoe (A66408)
John Deere 400...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2018 CATERPILLAR 320 EXCAVATOR (A65053)
2018 CATERPILLAR...
