Culvert for creek?
/ Culvert for creek?
AgriSupply has the Dual Wall Soil Tight pipe and there is a store in Garner.
Dual Wall, Soil Tight Drainage Pipe, 12 In. x 2 Ft., ADS
However, looking at your stream, you have a lot of twists and turns. This pipe is not flexible so may not be the answer.
The main part of the stream that is diverting is basically straight. Can you suggest something that might work better if I did have to have it installed in parts of the stream that curve or wind?
/ Culvert for creek? #22
You are WAY over thinking this!
What you need is 12" black flexible corrugated culvert pipe.
/ Culvert for creek? #23
Use a backhoe and dig a sloped trench/ditch for the stream bed. Put the plastic down and then line it with crushed stone rocks over the plastic. Slope it with measurements so that it is alway running down hill. It should last forever.
I thought the same, but have zero knowledge on this matter. I think Lowes has 20' x 12" sections for $ 150.....which means maybe a landscaper has it for much less.
/ Culvert for creek? #27
That is just too simple! Cheap, simple, non clog, easy clean!
/ Culvert for creek? #28
Did someone mention Florida Sinkholes??
[video]https://pubs.usgs.gov/of/2000/0294/report.pdf[/video]
Pemberton Inc 416469 72in. Loader Forks and Frame (A64194)
Pemberton Inc...
EZ Guide 500 Remote (A65640)
EZ Guide 500...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
2023 NISSAN ALTIMA SEDAN (A59914)
2023 NISSAN ALTIMA...
F-450 SuperDuty Flat Bed 4WD (A63689)
F-450 SuperDuty...
2012 International DuraStar 4300 Digger (A62613)
2012 International...
