Coolant Ph
/ Coolant Ph #1
unhappykioti
I have not seen anything in my owners manual about checking the coolant Ph levels. I own an 18 wheeler and have the Ph level checked at every service because if the Ph is not kept with-in the proper range it will pit the piston liners and eventually corrode the liners and allow water to get in to the pistons. This happens to diesel pick-up trucks as well. Just assuming this will also happen with these tractors.
/ Coolant Ph #2
I believe the manual suggests a change of coolant at a certain number of hours/years. Can't recall seeing this discussed on the other brands either. There has got to be a lot of diesel tractors out there that never had this checked and some are going strong after many, many, many years.
happykioti owner............... /forums/images/graemlins/grin.gif
/ Coolant Ph #3
Your tractor does not have liners in the cylinders. Many smaller diesels are no longer sleeved cylinders...
/ Coolant Ph #5
Changing the coolant regularly as mentioned in the manual is probably still a good idea to keep the radiator in good shape. Aluminum radiators like a ph of 7 and can corrode fast if it gets to low. Most car makers suggest the ph be checked and adjusted. Luckily, the tractors still have brass radiators which are more tolerant of ph levels.
/ Coolant Ph #6
At least the Kiotis appear to be non-aluminum. The kubotas have moved to aluminum cores.
/ Coolant Ph #7
Interesting thought about PH. I've used distilled water in radiators for a couple of decades cuz of hardness. Just did a net search and several hits said "distilled" water has a neutral PH (7).
/ Coolant Ph #8
Supposedly as antifreeze/water solution ages, the pH becomes more and more acidic. For this reason, flushing the system is recommended at an interval.
/ Coolant Ph #9
Yep, That's my understanding and procedure too ... flush with filtered, refill with distilled and antifreeze.
/ Coolant Ph
In diesel engines when you add anti freeze whether it is a complete flush and fill or replenishment you need to add an additive to balance the Ph two of the most popular that I know of are NALCOOL and PENCOOL and then the Ph needs to be periodically checked. They also now have coolant for heavy duty applications with the aditive already in it. This is how it is with trucks anyway. If you have ever seen the liners that come out of engines that have had the coolant neglected you would know what i mean
/ Coolant Ph #12
</font><font color="blue" class="small">( This is how it is with trucks anyway. If you have ever seen the liners that come out of engines that have had the coolant neglected you would know what i mean )</font>
I have seen it. Pin holes in the liner from the outside inward.
These were on wet sleeved engines (the coolant runs directly around the cylinder liner).
My Kioti tractor does not have wet sleeve type cylinders.
/ Coolant Ph
check out shopdiesel.com they can explain it better than I can.
/ Coolant Ph #14
I do my truck and wife's car every 3 years, @ 30k miles. My previous truck, bought new, was 16 years old with about 150k miles. I never had a problem with the radiator. Distilled water is nice because all the minerals should be gone. I never knew it was a ph of 7.
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
2017 Ford Box Truck (A62613)
2017 Ford Box...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
