Concrete Posts.
   / Concrete Posts. #11
go to carpet store and ask to haul off the cardboard tubes from the carpet rolls set them in the post hole and fill with concrete
   / Concrete Posts. #12
here is a picture of concrete posts. I took this picture at a building supply in France. They also use concrete for their power poles.
   / Concrete Posts. #14
Maybe the drawing will help explain what I meant.
Instead of using a PVC pipe cast in the post to bolt the boards.
How about a slot in the post to bolt the boards. The slot would give wiggle room to adjust the board.
Later,
Dan
   / Concrete Posts. #17
   / Concrete Posts. #18
Thanks all.
rvaitor - see I knew someone would have insight and support!!!!
Here you go, this may compliment what others have posted, I haven't gone through them yet.
  • Concrete Post color .PDF
   / Concrete Posts. #19
Those are the same style as the ones that I saw when I was in Argentina. They had those wires through them and they attached woven fence wire to the through post wires.
Aaron Z
   / Concrete Posts. #20
Aaron Z
These were cast on site with the forms per the plans on the PDF file. I still have the forms, just not ready to start making posts. I think I have a pic of the forms, but it could take a while to find.
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
71050 (A49346)
71050 (A49346)
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
2017 Dodge Grand Caravan (A50324)
2017 Dodge Grand...
Quick Attach Pallet Forks (A47384)
Quick Attach...
