Concrete Posts.
   / Concrete Posts. #11
go to carpet store and ask to haul off the cardboard tubes from the carpet rolls set them in the post hole and fill with concrete
   / Concrete Posts. #12
here is a picture of concrete posts. I took this picture at a building supply in France. They also use concrete for their power poles.
   / Concrete Posts. #14
Maybe the drawing will help explain what I meant.
Instead of using a PVC pipe cast in the post to bolt the boards.
How about a slot in the post to bolt the boards. The slot would give wiggle room to adjust the board.
Later,
Dan
   / Concrete Posts. #17
   / Concrete Posts. #18
Thanks all.
rvaitor - see I knew someone would have insight and support!!!!
Here you go, this may compliment what others have posted, I haven't gone through them yet.
  • Concrete Post color .PDF
   / Concrete Posts. #19
Those are the same style as the ones that I saw when I was in Argentina. They had those wires through them and they attached woven fence wire to the through post wires.
Aaron Z
   / Concrete Posts. #20
Aaron Z
These were cast on site with the forms per the plans on the PDF file. I still have the forms, just not ready to start making posts. I think I have a pic of the forms, but it could take a while to find.
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2019 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
