Concrete Posts.
   / Concrete Posts. #11
go to carpet store and ask to haul off the cardboard tubes from the carpet rolls set them in the post hole and fill with concrete
   / Concrete Posts. #12
here is a picture of concrete posts. I took this picture at a building supply in France. They also use concrete for their power poles.
   / Concrete Posts. #14
Maybe the drawing will help explain what I meant.
Instead of using a PVC pipe cast in the post to bolt the boards.
How about a slot in the post to bolt the boards. The slot would give wiggle room to adjust the board.
Later,
Dan
   / Concrete Posts. #17
   / Concrete Posts. #18
Thanks all.
rvaitor - see I knew someone would have insight and support!!!!
Here you go, this may compliment what others have posted, I haven't gone through them yet.
  • Concrete Post color .PDF
   / Concrete Posts. #19
Those are the same style as the ones that I saw when I was in Argentina. They had those wires through them and they attached woven fence wire to the through post wires.
Aaron Z
   / Concrete Posts. #20
Aaron Z
These were cast on site with the forms per the plans on the PDF file. I still have the forms, just not ready to start making posts. I think I have a pic of the forms, but it could take a while to find.
2012 Wells Cargo CEW202 24ft T/A Enclosed Trailer (A50324)
2012 Wells Cargo...
2016 Nissan Altima 2.5 (A50324)
2016 Nissan Altima...
2024 New Holland T8.410 MFWD Tractor (A52128)
2024 New Holland...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
TEST YOUR BID BUTTON! (A51242)
TEST YOUR BID...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
