compact TLB vs. full size TLB
   / compact TLB vs. full size TLB #21
Kendall69 said:
First of all they haven't made the perfect tractor for all needs yet, and never will.
Seems like there's a lot of comparing apples to hand grenades here. For the construction guy who needs massive power, massive lifting, great we all know what machines they should own.
For the "others" yes get the smaller MORE USEFUL tractor that can do 75-80% of what you need to do, and either rent or contract out the other. For the average non contractor type, the small utility tractors are perfect, hence the reason most manufacturers are producing them when Kubota was one of the first many. many years ago.
I doesn't make sense to buy a full size tractor just to dig your foundation or septic, then be stuck with the beast for years to come or have to take a beating on selling it, or even the hassle of selling.
For me the Small Kubota with a backhoe was perfect, I dug 600 feet of trench four seperate times, and many other tasks. did I do them as fast as "the big boys" no, but for me it didn't matter, I'm not on a schedule.
Did I need more lifting or power, you bet, when I had to clear 4 acres of trees, so I rented dozer, and did it it in eight hours, for $800.00 - and not even the big loaders could have accomplished that task.
So buy a long range usage tractor, one that will do the "most" and rent for the extra oomph, if you need it.
I used to hate renting, now I’m a huge fan of renting. Also contracting out is my new best friend. To mulch the four acres I was quoted $100.00 per hour for four guys, a chipper, and a dump truck. Even I couldn’t beat that on my own, renting just the equipment.
Oh, and yes mine was out in the 117 degree plus sun, at times 365 days a year, for almost 10 years before I sold it, with no problems, not even a rotten belt or hose.
Something tells me our thread starter is gonna spend a heck of a lot more than $800 in rentals to get his house foundation and septic system and driveway dug if he buys an L-48!
Probably more like $8,000-$18,000.
Lookie here guys: 5 months ago, before I bought my Case, I bid on (2) 1-acre building lots intending to build 2 houses. I got a price from an excavator I play golf with to put in 2 driveways, 2 septic systems, 2 foundations and 2 rainwater retention systems and backfill/grade (2) 1 acre building lots. Total cost $40,000 + !
That's why I bought my Case backhoe! I said "screw this" I'm going out and getting another full size backhoe. I spent just a little over what the excavator would have charged me for 2 houses! Now I can do all the excavation work myself AND keep the machine for many years to come!
My guess is our thread starter will spend $15,000-$20,000 hiring a professional to clear trees, cut a long driveway and dig the foundation & septic system cause even if he spends $30-$40 grand on a L-48, it won't be able to do the big jobs.
So now our guy has spent $30-$40 grand on a small backhoe that will basically be used for backfilling, a few trenches and some other small stuff.
I say buy the big TLB to handle the big expensive stuff and buy a $10,000 used farm tractor for the small stuff, or sell the full size TLB when he's done with it. Chances are it won't depreciate more than a few grand yet it will save him at least $15-$20 grand because it can do the big work an L-48 just can't ever do.
   / compact TLB vs. full size TLB #22
That wouldn't be a bad price up in NH. The septics can run 10,000 or more with availability of septic sand and other materials. One acre building lot here could require a shared septic. One subdivision has 2-4 houses per septic. It is an aeration system. The special septic tank for unit costs 6000.00 dollars. Wells for water require a buffer from septics unless central water supply. Some banks won't lend money to buyers of houses with shared services. plowking
Wow, there is a lot of information here. I appreciate everyone's input. I've read every post 3 times now.
A few more random bits of info after reading through all of this:
I've got a riding mower and don't plan on having any more grass than it can handle. Whatever I buy won't be used for cutting grass.
The pole barn I'll build will be able to house a full size backhoe also, so storage is not an issue.
I'm 100% sure that the profesionals can accomplish what I'd like to have done much faster than I can. I spent a few years working as an electrical contractor, so I know the importance of chasing the fast buck and not the last buck. However, in this case I'm doing the exact oposite. I've got a vision for what I want the house/land to look like and I want to take my time and do it right. Like AlanB, I like doing my own work, even if it takes longer. At least it will be the way I want it in the end. And in general, I really enjoy construction work. On the other hand, like Builder suggests I don't want to spend $30-40k on a L48, only to end up spending almost as much in rental fees or even hiring out the majority of the work. I'd like to save money by doing the work myself, not the other way around.
   / compact TLB vs. full size TLB #24
Exactly. I can tell you right now, if you try to do what I think you're gonna do with an L-48, you'll just end up hiring or renting bigger machinery to do the work while your 35-40K L-48 just sits on the porch & watches the big boys get the job done.
Then when there's an opportunity for it to do some work, you'll use it, but I get the idea that's not what you set out to do.
Or you can buy a big TLB that probably won't have to sit on the porch, it'll always be able to be in the game unless you hit HUGE rock.
   / compact TLB vs. full size TLB #25
for the thread starters uses i have to agree with builder. i feel i could do all the work he needs to do but it definitly would take longer. for the work i do with a compact tlb the L48 didn't impress me at all. i don't mean this as a swipe at the machine because it is obvious it fits a niche for many. just not me. it is shame also because our local dealer is a great guy and would be great to do bussiness with.
another consideration in the ctlb vs. tlb arguement is weight. i like to joke and say i am an ankle biter in the excavation bussiness, just starting out. most of the jobs i am doing are the ones no one else wants because they are too small. i am able to string a couple together for a good day rarely am i on jobs that more than a couple days. this makes it very easy to move around with my one ton truck and when working on a homeowners yard i am not running an 8ton machine across his grass. usually i leave no marks at all. in new home building this isn't as much of an issue. but again i take whatever i can get to keep the jobs rolling in. also on the smaller jobs fuel consumption is another way to save. i guess if it is to dig a trench to run a new sewer line 60" long the full size machine would do it faster but would also burn more fuel getting there and doing the job, make a bigger mess and have a harder time dodging trees or lanscaping. and for a 4 ft deep trench i'm not sure the speed would make it enough better for this job to cover the downsides. each has a place and a purpose.
still the dream is to have a jd 310j with all the amenities. but so far i can't justify it. hopefully within 2 years i will be shopping. AC would sure be nice these hot august days.
good luck with your decision,
   / compact TLB vs. full size TLB #26
Builder,
I thought I was through with hiring out until I figured I was still 4' to 2-1/2 ft high over the whole yard and foundation area.
That amount of work would be a real challenge for a full size TLB. Even with the PC75 excavator, it would surely kill the L39. That much volume would be work for my excavator also. So I will hire out a Rock Truck, Dozer and Excavator.
At least I have a good use for this material. I will build a 28' X 36' or 38' storage building for building materials and my equipment on a pad from the moved spoils.
I still have long list of tonnes of work for both my machines so they will not "sit on the porch" for sure.
I can see the advantages of using a excavator/dozer combo, but I think since I'm not really in a rush, this may be the best approach for me:
Builder said:
I say buy the big TLB to handle the big expensive stuff and buy a $10,000 used farm tractor for the small stuff, ...
Now, where do I learn more about full size TLBs? Is there a tbn for backhoes? I'll start by looking through this forum. I'm sure there's plenty of good info here.
   / compact TLB vs. full size TLB #28
The holy grail of one size fits all is much sought in many venues. I did consider a TLB before I went with the compact track machine, and I know that things are improved since I worked with the old MASSEY-FERGUSON, but I can't forget how clumsy it was to get through the day with all those assets hanging off both ends. It was a real boat in both directions and generally too high for any woods work. I felt like a one man band no matter the job. Call me crazy, but if the machine doesn't make it easier and more fun, I'd rather hire it out or do it by hand. Here's the difference between us, I enjoy the process. If you just want to get er done, then go with the tried and true full size TLB.
jmf
   / compact TLB vs. full size TLB #29
I do a lot of tight excavation and grade work and wanted to get two specialty machines instead of a middle of the road / do it all machine.
I bought a CAT 247B tracked skidsteer and we currently rent excavators, but are about to pick up a Komatsu PC-35. They run the same price together as a CAT 420E backhoe, but they can do so much more as individual units.
Now having said that, if I could only own 1 machine, it would be a backhoe. Especially if I were using it on acreage. Why? Tons of breakout power on the hoe, high speed travel around the property, lots of loader capacity, and the ability to pick up a used one really cheap. They are near indestructible under basic farm usage and parts are easy to get.
I almost bought a L48 and it's a nice machine, but they just aren't built for the heavy construction trade. I've used a Case 580K backhoe in an industrial setting that had 11,000 hours on it. That thing has been abused during it's entire existence, but it keeps on running. You can pick one up for a low price with just a few thousand hours and they usually hold up well.
A lot of cities buy them for snow removal and general maintenance, but they get little use. My buddy picked one up that had been used by a city in Washington. It only had 300 hours on it and he picked it up in next to mint condition for $30,000. The thing practically still had the dealer sticker in the window! ;) They bought it for snow removal in city parking lots, but it rarely snowed, so they sold it. Score!
My general rule is to look at the job you have and buy the next larger machine that will still fit in the operating space you are working in. Gauge your work load and size up one notch. Good luck.
   / compact TLB vs. full size TLB #30
White Shark said:
. My buddy picked one up that had been used by a city in Washington....They bought it for snow removal in city parking lots, but it rarely snowed, so they sold it. Score!
HAHA, that's funny! No snow in this state except east of the cascades and even that isn't that much.
JPCjr said:
. Now, where do I learn more about full size TLBs? Is there a tbn for backhoes? I'll start by looking through this forum. I'm sure there's plenty of good info here.
There should be good info out there but you can also touch base at HeavyEquiptmentForums.Com also. A lot of contractors there that can help you compare a Case vs. a Deere vs. a Cat etc. etc. Personally you're going to find an older Case running much better than other brands out there, Deere being second in my opinion. Not sure on your budget but there are some good 580K's and 580L's out there still in good condition, and if you have to go older Case is still running strong.
Blake
WA
Adams Tender / Magnolia Trailer (A56438)
Adams Tender /...
John Deere StarFire 6000 (A59814)
John Deere...
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
2009 1770 NT 16R Planter (A59814)
2009 1770 NT 16R...
2016 KOMATSU D65PX-18 CRAWLER DOZER (A60429)
2016 KOMATSU...
John Deere 1025R (A53317)
John Deere 1025R...
