Xfaxman
Super Star Member
- Joined
- Feb 8, 2013
- Messages
- 13,323
- Location
- Guthrie, OK
- Tractor
- Toolcat 5610 G - Bobcat V417 - TORO+Loader
The missing pictures are still in this thread:Post #35 View attachment 360037 View attachment 360038
Used the tree puller on the biggest cedar tree that I have tried to pull so far. It is about 5" in diameter.
Raised the rear end when I tried to pull it straight up, so I curled down while pulling up and moving forward. That broke some roots loose. You can see the crack in the ground.
Curled up while pulling up and moving backwards. That broke some roots on the other side.
Went forward again and it started coming up.
Raised the boom, the cedar came out of the ground and brought another tree with it!
Shook the dirt off of the roots and the other tree fell to the ground.
It looks to be about 3" in diameter.
1 pull, 2 trees!![]()
The problem, concrete around a broken wood post.
The solution, the Gorilla Grapple.
And the V417
The new problem, a big hole in the pasture.
The solution, the stump bucket also hauls dirt.
Pack it down, no problem
looks like you are having too much fun with the tele.
My dealer tried real hard to steer me clear of a 417 though I felt it would fit my business perfectly especially when handling the big oaks. How's yours holding up?
Well it is a free Website and you are entitled to your opinion even if it is wrong in my opinion.A Compact Track Loaderr or Multi-Terrain Loader, especially the 2-speed varaints, will do everything you do with your telehandler except the high lifts quicker, cleaner and more efficently and cost a lot less. I've never gotten a CTL stuck even driving over freshly dumped snow piles.
The Versahandler may be the best over all machine in it's size.... EVER!!
Problem is, I can't afford one, Nuts!
No, haven't needed to. But I think it would pull a 8' or 10' disc. The European version has rear hydraulic remotes that I could add to mine.Have you ever tried discing or plowing?
Thanks, it seems to be able to do everything that I need done here. :thumbsup:You have definitely got one of the coolest setups.
