Compact telehandler
/ Compact telehandler #41
Re: Three Castor Storage Dolly
Made a three castor storage dolly for the three point adapter. This one is an old 2x12.
The adapter with the Omni Transformer Hitch for a three point.
Replaced the pictures that disappeared from Post #39.
/ Compact telehandler #42
Post #35 View attachment 360037 View attachment 360038
Used the tree puller on the biggest cedar tree that I have tried to pull so far. It is about 5" in diameter.
Raised the rear end when I tried to pull it straight up, so I curled down while pulling up and moving forward. That broke some roots loose. You can see the crack in the ground.
Curled up while pulling up and moving backwards. That broke some roots on the other side.
Went forward again and it started coming up.
Raised the boom, the cedar came out of the ground and brought another tree with it!
Shook the dirt off of the roots and the other tree fell to the ground.
It looks to be about 3" in diameter.
1 pull, 2 trees!
:D 👍
The missing pictures are still in this thread:
/ Compact telehandler #43
Replaced the pictures that disappeared from Post #31.
The problem, concrete around a broken wood post.
The solution, the Gorilla Grapple.
And the V417
The new problem, a big hole in the pasture.
The solution, the stump bucket also hauls dirt.
Pack it down, no problem :D
/ Compact telehandler #44
looks like you are having too much fun with the tele.
My dealer tried real hard to steer me clear of a 417 though I felt it would fit my business perfectly especially when handling the big oaks. How's yours holding up?
/ Compact telehandler #45
So far, so good. :thumbsup: Had to adjust the tension on the main drive belt last week.
It will be 4 years old the end of September, only 748 hours on it, so not using it as much now as when we first moved here.
It is a GADA machine! (Go Anywhere, Do Anything) :D
/ Compact telehandler #46
This double trunk cedar was cut with a skid steer tree cutter long before we bought this place.
Look for the dead trunks in the first picture. Hooked a chain to each one.
Raised the boom and backed up.
Picked them up and dropped them on the pile.
Compressed the pile, notice that the front wheels are off the ground.
The tree cutter wasn't big enough to completely cut one of the trunks, that is why it is green on top.
/ Compact telehandler #47
Removing The Cracked Concrete At The Barn
A project from last June. The barn porch concrete had low spots and major cracks.
Braced the truss so I could cut off and remove the support posts.
The slab is only 3 inches thick and no sand under it. Used the Gorilla Grapple to pick it up and the dumper to haul it off.
Ready for the concrete guys.
/ Compact telehandler #49
A Compact Track Loaderr or Multi-Terrain Loader, especially the 2-speed varaints, will do everything you do with your telehandler except the high lifts quicker, cleaner and more efficently and cost a lot less. I've never gotten a CTL stuck even driving over freshly dumped snow piles.
/ Compact telehandler #50
Well it is a free Website and you are entitled to your opinion even if it is wrong in my opinion.
I don't know what your opinion is based on, but mine is based on using both types of loaders and I gladly paid for the extra versatility.
I have used a Bobcat T300 CTL with my one cubic yard bucket, in the same shale pit as my V417 and the CTL didn't do as well or as quickly.
I don't think any CTL could have removed the silt from this pond like the V518 Compact Telehandler did.
/ Compact telehandler #51
The Versahandler may be the best over all machine in it's size.... EVER!!
Problem is, I can't afford one, Nuts!
/ Compact telehandler #52
Yep, quality costs more and this is an awesome machine. We bought it in September of 2010, a demo with 44 hours, for $52K.
It has done everything we have needed a machine to do on two different 80 acre horse ranches. I have never had to rent anything to do a project. Now granted I have had to buy attachments, but they get used enough to justify the purchase.
Edit: The Tilt-Tach is one attachment that hasn't been used enough to justify it's cost.
But it has been used some and I can use it with the bucket, box blade and pallet forks. EDIT and now with the land plane.
Land plane:
Have also used it on the Toolcat.
/ Compact telehandler #53
Found this chart in a PDF brochure.
Note the turning radius, inside 4' 11", outside, 10' 5", plus the 6' 5" cab height, is why it gets around good in the woods. :thumbsup:
/ Compact telehandler #54
Have you ever tried discing or plowing?
/ Compact telehandler #55
No, haven't needed to. But I think it would pull a 8' or 10' disc. The European version has rear hydraulic remotes that I could add to mine.
The holes are there.
/ Compact telehandler #56
Here is a project from last summer that shows how handy crab steer is.
Used some wood to clamp a 1-1/2 inch square tube in the Gorilla Grapple.
attachment.php
attachment.php
attachment.php
attachment.php
Lined up the tube with the hole in the sod roll.
attachment.php
Switched on crab steer, turned full right, backed up while extending the boom, the tube goes into the hole.
attachment.php
Stopped and turned full left, went forward while retracting the boom, until it was all the way in. Then picked it up.
attachment.php
attachment.php
/ Compact telehandler #57
/ Compact telehandler #58
Had the stump bucket on last week and pushed over some dead Oak trees.
Put the Gorilla Grapple on today and got them out of there.
Picked up some small limbs an put a chain on the long trunk.
Drug it through the woods to where I put the first three.
Picked it up and added it to the pile.
Extended the boom with max dump on the grapple.
Lowered and retracted the boom.
Closed the grapple and picked them up.
Took them to the burn pile. :thumbsup:
/ Compact telehandler #59
You have definitely got one of the coolest setups.
/ Compact telehandler #60
Thanks, it seems to be able to do everything that I need done here. :thumbsup:
From last April, pulling a 15' tall cedar tree.
The view from the seat.
Headed to the burn pile.
2013 John Deere 2623VT Vertical Tillage Tool (A63116)
2013 John Deere...
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
207279 (A52708)
207279 (A52708)
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 PETERBILT 579...
