Clearing Woods - what attachments?
/ Clearing Woods - what attachments? #1
602466
Silk Hope North Carolina
New Holland TC40D
I am in the process of clearing about 4 acres of woods. Taking out some dead trees and clearing the under brush. I am using my FEL on the trees and some of the brush. I want to keep it clean. What should I use once all is cleaned out to keep it that way? Do I use a rake, harrow, scrapper, box blade to keep the brush down? The FEL gets the big stuff but not too good on the weeds. The soil is that red clay so its hard as a rock.
Thanks in advance!
Wally
/ Clearing Woods - what attachments? #2
bush hog? the only way I know is keep it mowed with a bush hog.
/ Clearing Woods - what attachments? #3
The only way to keep it under control is to mow it. You can spray with chemicals to kill off the broad leave plants and just have grass, which will make mowing easier, but you'll still have to mow.
Eddie
I guess I am going to be taking out more trees to make the bush hogging easier and faster.
Thanks for the replies!
Wally
/ Clearing Woods - what attachments? #5
Taking out more trees isn't always a bad thing. Trees that have more room between them, are usually healthier, stronger and bigger.
Eddie
Eddie:
Yes you are right. I have taken down about 75 trees stumps and all. Most of the trees were insect infested. I had a friend that knows about forestry come over and pick out the trees that should be removed. Now I have two huge piles of this mess that I can't get ride of. I had a guy come over with a big tub grinder and give an estimate of 5,000.00 to grind and bury the bigger stumps. I took down the trees back in October. I cut truck loads into fire wood and put out a sign for free firewood, no takers. Its still too close and dry to light up those huge piles (you know I want to). I am now going into those piles, dragging trees to cut into smaller pieces to burn into smaller piles. So the thought of taking down more trees to add to the pile is not a pleasant one.
Thanks for the reply!
Wally
/ Clearing Woods - what attachments? #7
Wally,
It sounds like we're in the same situation. I've tried over and over again to give away good oaks and pines. I get a few people that are interested, and a few that even show up. Twice I actually had people take some away, but then they never come back again.
It's turned out to be allot easier to get them "OUT" of the ground then it is to get them "OFF" of the ground!!!!!!!!!
I just finished building some forks for the front of my FEL that have been amazing at picking up lots, stumps and even branches. Now it's become allot easier and faster to get them to the burn pile. I still haven't tried raking up some piles and picking them up yet, but I'm pretty cofident that will work too. If you don't have a Grapple or 4 in 1 FEL, then I highly recomend some bucket forks.
Eddie
Eddie:
This is my first tractor. I got the Bush Hog M246 FEL without the quick connects. I think it was or is an option. I will look into that to purchase a grapple for the FEL. You learn after a couple of weeks of manually loading the FEL with wood to bring over to the burn piles the hard way. Next purchase, more research and thinking ahead of the jobs to be completed.
Thanks for the advice.
Wally
/ Clearing Woods - what attachments? #9
The grapple is the perfect, ideal tool for moving trees and branches, but it's also allot of money. Then getting it connected can be rather involved with running hoses and getting it all plumbed right. If you go that rought, be sure to post it here, because there are allot of guys who have done it and they can give you some pointers, or help you out.
Here is the link to what I just built that has been working out better then I had hoped for. You still have to balance the load, but it's really not an issue. My dad is here visiting and he's in his 70's. He's not the best at new ideas or finessing things, so my biggest concern was if he could use it. He loves it and we're both excited about how easy it is to pick up material and move it to the burn pile!!!!!
http://www.tractorbynet.com/forums/build-yourself/102060-forks-my-fel.html
Eddie
/ Clearing Woods - what attachments? #10
If you guys want to drop those trees off, Ill take them all. Of course, it may be a long drive to NH. Up here, its tough to find free wood.
Great job Eddie. I wish I had all the tools needed to make one!
Wally
/ Clearing Woods - what attachments? #12
Eddie you know this isn't a bad idea for you. Instead of burning trees or giving them away you should be cutting and splitting them so you can sell firewood to your campers when they arrive :)
/ Clearing Woods - what attachments? #13
Block them...yes.
Don't split them yet. Leave that part until the season before the firewood is actually needed. It won't rot as much that way.
So Eddie,
What is the expected time frame for opening the park? I'm sure you've mentioned it before, but can't recall...
/ Clearing Woods - what attachments? #14
No time frame. The land and everything is paid for, so I'm not in any sort of rush. The goal is to do all the tree removal and dirt work for cash before taking out the loan for building the Park. Then I only have to borrow enough to build what I need built and not pay hundreds of thousands of dollars for what I can do myself over time. If I open in ten years, that might be just about right.
Eddie
/ Clearing Woods - what attachments? #15
Ah...
Ten years...
Don't bother stockpiling firewood yet.
:rolleyes:
That might give me just enough time to afford a nice RV so I can come down & try out the park. :)
/ Clearing Woods - what attachments? #16
I was going to say the same thing - you beat me to it. Maybe if they make the drive, we can split the spoils.
JayC
XR400
GG125xc
/ Clearing Woods - what attachments? #17
Call up your favorite trucking company & ask how much to haul a tandom dump load about 800 miles...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
2006 Heil DOT 406 Comp Fuel Tanker (A64194)
2006 Heil DOT 406...
2004 Chevrolet Trail Blazer 4x4 SUV (A64557)
2004 Chevrolet...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
Kohler Gasoline Air Compressor (A64553)
Kohler Gasoline...
1000 GALLON FLAT BOTTOM POLY TANK (A64278)
1000 GALLON FLAT...
