Need some bush hogging advice
/ Need some bush hogging advice #41
After reading the entire thread and all the 'armchair quarterbacking' that always goes on, on this site, if it was me, I'd just pass on the job. Sounds to me like a ton of grief even if it appears assy.
/ Need some bush hogging advice #42
I don't know if this is in the right category but I figured I would try. Boyfriend can drive a bush hog and has done it in the past. Just got hired to bush hog 11 acres in Georgia. Property hasn't been cleared in 10 years so lots of scrub trees, pine trees. Want down, a lot of brush, thickets and thorns. Also, they want a fence line cleared on both sides and they have a 100-yard chicken coop which has been abandoned but want all the vines, brush, etc cleared out from both those areas And the bush hog won't be able to get that close. So we understand the closer work's going to have to be done with fiska's weed eaters, rakes The fence line is really on two sides and the coop has all four sides which need to be done. Terrain is fairly flat and he will be using the gentleman 's brush hog which is a John Deere tractor. I'm not sure of how long the blade is. Could anyone ballpark how much that would be charged per acre including the? I guess it would be called trim work? There are approximately 60 pine trees that'll be taken down with a saw. So I know that I'm throwing a lot out here and asking for a price per acre. If you can give it to me that'd be great. If not, could you just provide as much info on any of these mini projects within a project? Thank you in advance
So, what did you end up doing?
2023 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2023 UTILITY VS2RA...
(3) Pieces of Poly Pipe (A62679)
(3) Pieces of Poly...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
2022 Keystone RV Coleman Camper Trailer, VIN # 4YDTCMN20NH931920 (A65563)
2022 Keystone RV...
8ft Rotary Cutter (A65579)
8ft Rotary Cutter...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
