Clearing Snow Off An Open Station
/ Clearing Snow Off An Open Station
Some great suggestions, guys. Thanks for being so helpful. Going to keep rolling with my big tarp and play around with positioning while I try to figure out a more permanent cover.
/ Clearing Snow Off An Open Station #22
You being from New England you know what freezing rain can do,I would cover dash and control levers also expose pistons.
/ Clearing Snow Off An Open Station #23
A complete shelter should be your goal. Sunlight really destroys tires... mine were weather cracking by the time they were 3 years old.
/ Clearing Snow Off An Open Station #24
Might consider a more substantial "temporary" shelter ""IF"" ROPS/Roof will fit under door frame...
Best check the snow load rating if going in this direction
/ Clearing Snow Off An Open Station #25
Get a carport put up and plywood at least the top half of the sides... You can always move it and reuse it for attachments and whatnot later.
/ Clearing Snow Off An Open Station #26
/ Clearing Snow Off An Open Station #27
Any way you can hang a tarp (off trees or the side of a building) at an angle to make a lean-to you can drive under? Even if the snow doesn't completely slide off a push broom will clean it off by pushing up on the inside to help it slide off, then you are ready for the next storm. It would be easier to drive under something than to
tarp-on/tarp-off each time.
/ Clearing Snow Off An Open Station #28
If it has not already been said, you should add Power Service diesel fuel supplement (white bottle) to prevent fuel gelling.
Congrats on your new rig!
/ Clearing Snow Off An Open Station #29
Why not buy a car cover…
/ Clearing Snow Off An Open Station #30
Using ANY open station tractor for snow removal is purely a self inflicted injury thing. I'm not that nuts. I like heat and comfort.
/ Clearing Snow Off An Open Station #31
Meh. Not going to pay almost $3k for something that's more bother than it's worth 9 months out of the year. My driveway's only a couple hundred feet, I can handle the cold for the amount of time it takes to clear it.
Mine usually lives in the garage in the winter, but if I make sure to flip the seat up, it supports a tarp well enough.
/ Clearing Snow Off An Open Station #32
I had my M4700 in Virginia for a while.
I placed "rails" going down from the canopy to the loader arms and put a tarp over the top. fastened mostly with 1/4" rope. Made like a small tent. That way the snow and ice was relatively easy to slide off.
Moving to Mississippi into a 20x50x15H shed solved the problem.
/ Clearing Snow Off An Open Station #33
There are ways to prevent the wrath of mother nature without having to enclose yourself in glass! I have been known to ride a motorcycle in all types of weather, and do it without issue. Instead of paying $3000. plus for a cab, why not just buy a set of 12volt clothing and run it off the tractor? That can be accomplished for about $300! I would assume that even with the glass, you still have to bundle up? I drove a forklift for years, and cold hands/feet were a part of the job. I acquired a small heater core, put it in a box, added a 12v fan and plumbed it into the forklifts coolant system. It blew hot air over my feet, and if my hands got cold, I could reach down and warm them. Such a device would probably help if properly positioned around the operators station.
Granted I am from Florida and have NEVER done any snow removal at all, not ever! Even when I do encounter in during my travels, removal isn't my issue!
David from jax
/ Clearing Snow Off An Open Station #34
I do it every storm... including the one we have now. I work outside all week anyways and as long as you have the proper clothing it isn't bad. Much better than mowing on a sunny 85' day...
/ Clearing Snow Off An Open Station #35
I guess but I'm not about to do it anyway.
/ Clearing Snow Off An Open Station #36
I've done both for a great many years, snow with no cab bundled up snow down my neck,
mowed in 85+ temperatures with high humidity.
Dang, was I ever glad when the farm got cabbed tractors with AC for summer work and heat for the winter work.
Kicked myself in the butt more then once for waiting as long as I did before getting my cabbed tractor for snow
and summer use.
/ Clearing Snow Off An Open Station #37
Having previously owned an open station I second the oversized canvas tarp. Chicago Tarps are top notch and well worth the money spent. In that regard, so are cabbed stations (during both hot and cold days).
In the event I have a project going on in my barn, and/or don’t want to open the overhead door (letting all the heat out while I’m working), I will cover up the front end of my cabbed tractor as well. Granted it’s not completely necessary, but it takes less time for things to warm it up the next time I use it. I’m still using the same canvas tarp for my tractor implements that I have been using for almost ten years. During the winter and into spring, I will often throw a cheap tarp over top of the canvas one, as it’s easier for snow removal, and helps to keep the canvas tarp “dry”.
Regardless of which route you take, ensure to let things warm up as @rScotty mentioned above.
Yeah, I've got the black K100 in all my fuel. And thanks man, she's such a monster. I have GOT to add a rear work light though.
To all the people recommending a permanent shelter I think I've settled on fixing up my old carriage barn. The loft is rotted and it needs a new roof but structurally it's 100%. It's got old growth rough cut mortise and tenon construction with lag bolts. The walls are dry and the supports are huge. It's older than living memory.
/ Clearing Snow Off An Open Station #39
I've used a tarp from the hood to the rear 3-point for 20+ years. Getting it around the ROPS can be challenging sometime. The snow we had earlier this week was a pain, but the tarp kept the tractor dry in the important areas. I put a 5-galloon bucket upside down on the seat to keep the tarp from sagging. The tarp only covers about 8-10 inches down on each side so I don't have the issue of condensation in the cab area.
/ Clearing Snow Off An Open Station #40
They tend to come in handy and are definitely one of my favorite add ons!
