Cheap Key Safe
   / Cheap Key Safe #1
moonlite
To make a cheap key safe , get a discarded fuse panel and attach some cable or conduit to look effective and take out the insides and install hooks. Most people would never think to look there. You do not know where I live!
   / Cheap Key Safe #2
Yeah,... but it's easy to get close with your IP address.. ;)
soundguy
   / Cheap Key Safe #3
Lots of panels have locking capability :eek:
Soundguy -- if you can find me by my IP address my internet provider does not have enough customers:rolleyes:
   / Cheap Key Safe #4
My research puts you somewhere in Eastern Ontario. :eek:
   / Cheap Key Safe #5
well that should narrow it down.. there are like what? 3 roads in canada ;)
soundguy
   / Cheap Key Safe #6
Only one road the goes east and west:D
   / Cheap Key Safe #7
Makes our maps simpler:p:p -- and no need for GPS, however that one east west road is 16 -20 lanes in spots and always seems to have some American driving in the fast lane @ the speed limit:rolleyes::rolleyes: -- last one I saw had Florida plates -- you been looking for me?
   / Cheap Key Safe #8
Moonlite -- welcome aboard and hope you will forgive the hijack -- your idea for the key safe is a good one. It would proably work well for a lot of small items. With the right stickers on it I am not sure anyone would ever look there -- including the electrical inspector:p
   / Cheap Key Safe #10
you guys crack me up! ;) all seriousness aside- the panel idea is a good idea when its placed in the right area. :) in the bedroom would be a red flag, wouldn't it ?:p
   / Cheap Key Safe #11
Depends on the electrical equipment you have in the bedroom:eek::eek::rolleyes:
   / Cheap Key Safe #12
Hmmmm....now I know what to do with the old fuse box with the knob and tube wiring!!
   / Cheap Key Safe #15
LMAO you guys sure know how to crack up a guy reading at work.But seriosly the elec box sounds great .But do as I do,sign reads "THIS HOUSE IS PROTECTED BY A SHOTGUN 3 NIGHTS A WEEK",you guess which "3".:D
   / Cheap Key Safe #16
When I was production engineer in tool factory - long time ago - I build a small safe myself. Since it was in Prague, all houses are brick or concrete and all you needed was the front plate and a hole in the wall.
Anyway, I found some scrap metal - it was CSN19552 tool steel for aluminum molds, I think US equivalent would H13 - one inch thick plate. I squared it on a mill and drilled as big hole as possible in the middle and on big lathe turned corresponding piece. For the lock I used a door lock insert with some modifications. There were no hinges, you had to unlock the round piece and take it all out. The whole thing was 20 pounds or more and to take the door out you needed both hands. But it was free - and the steel was an overkill:)
Reminds me of friends dad. He worked in a Airplane factory and in the heap pile found a fan from turboprop engine. Next thing you know, it was a cutting blade on his push mower:D
Dodge Charger (A56859)
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2005 Komatsu HM-400 (A60462)
2005 Komatsu...
2005 Peterbilt 387 with Wet Kit (A56438)
2005 Peterbilt 387...
