Changing mower blades
/ Changing mower blades #1
Cawinn
Culpeper, Va
I have a Bolen riding mower and can't get the blades off. I tried PB Blaster and a pipe on 1/2"ratchet, no luck. I tried heating the nut with propane torch, no luck. I finally borrowed father in-law's impact wrench, still no luck. Any ideas.
/ Changing mower blades #2
:welcome:
Looking down at the top of the deck, are the blades turning clockwise (throwing cut grass to the right) or counterclockwise (throwing cut grass to the left) ??
/ Changing mower blades #3
Maybe turning the wrong way?? Welcome to TBN.
/ Changing mower blades #5
Clockwise
It won't hurt to try the other direction. I think you can loosen them by cranking in the direction that the blade won't cut your knuckle if you slip with the wrench..
/ Changing mower blades #6
i had that prob once i used a big pipewrench then i hit the wrench with a big hammer, i jamed the blade with a piece of wood and managed to get it loose.
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
Kubota L3901HST
Kubota L3901HST
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A61573)
2017 Autocar...
