Changing mower blades
/ Changing mower blades #1
Cawinn
Culpeper, Va
I have a Bolen riding mower and can't get the blades off. I tried PB Blaster and a pipe on 1/2"ratchet, no luck. I tried heating the nut with propane torch, no luck. I finally borrowed father in-law's impact wrench, still no luck. Any ideas.
/ Changing mower blades #2
:welcome:
Looking down at the top of the deck, are the blades turning clockwise (throwing cut grass to the right) or counterclockwise (throwing cut grass to the left) ??
/ Changing mower blades #3
Maybe turning the wrong way?? Welcome to TBN.
/ Changing mower blades #5
Clockwise
It won't hurt to try the other direction. I think you can loosen them by cranking in the direction that the blade won't cut your knuckle if you slip with the wrench..
/ Changing mower blades #6
i had that prob once i used a big pipewrench then i hit the wrench with a big hammer, i jamed the blade with a piece of wood and managed to get it loose.
Hydraulic Stump Grinder Mini Skid Steer Attachment (A61572)
Hydraulic Stump...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Crustbuster 6020 TW36X6 (A64119)
Crustbuster 6020...
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
