Changing mower blades
/ Changing mower blades #1
Cawinn
Culpeper, Va
I have a Bolen riding mower and can't get the blades off. I tried PB Blaster and a pipe on 1/2"ratchet, no luck. I tried heating the nut with propane torch, no luck. I finally borrowed father in-law's impact wrench, still no luck. Any ideas.
/ Changing mower blades #2
:welcome:
Looking down at the top of the deck, are the blades turning clockwise (throwing cut grass to the right) or counterclockwise (throwing cut grass to the left) ??
/ Changing mower blades #3
Maybe turning the wrong way?? Welcome to TBN.
/ Changing mower blades #5
Clockwise
It won't hurt to try the other direction. I think you can loosen them by cranking in the direction that the blade won't cut your knuckle if you slip with the wrench..
/ Changing mower blades #6
i had that prob once i used a big pipewrench then i hit the wrench with a big hammer, i jamed the blade with a piece of wood and managed to get it loose.
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
We do NOT accept credit cards as payment. (A64119)
We do NOT accept...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
