Changing mower blades
/ Changing mower blades #1
Cawinn
Culpeper, Va
I have a Bolen riding mower and can't get the blades off. I tried PB Blaster and a pipe on 1/2"ratchet, no luck. I tried heating the nut with propane torch, no luck. I finally borrowed father in-law's impact wrench, still no luck. Any ideas.
/ Changing mower blades #2
:welcome:
Looking down at the top of the deck, are the blades turning clockwise (throwing cut grass to the right) or counterclockwise (throwing cut grass to the left) ??
/ Changing mower blades #3
Maybe turning the wrong way?? Welcome to TBN.
/ Changing mower blades #5
Clockwise
It won't hurt to try the other direction. I think you can loosen them by cranking in the direction that the blade won't cut your knuckle if you slip with the wrench..
/ Changing mower blades #6
i had that prob once i used a big pipewrench then i hit the wrench with a big hammer, i jamed the blade with a piece of wood and managed to get it loose.
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
TANK MANIFOLD (A58216)
Freightliner Columbia (A63689)
Freightliner...
2010 INTERNATIONAL PROSTAR PREMIUM ROAD TRACTOR (A63291)
2010 INTERNATIONAL...
2006 Chevrolet Silverado 2500HD Ext. Cab Knapheide Service Truck (A61573)
2006 Chevrolet...
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
