Chainsaw chain sharpening.......
/ Chainsaw chain sharpening....... #42
Jonsered anyone? I have a 2166. Made by Electrolux who also makes Huskies.
/ Chainsaw chain sharpening....... #43
Other then size of saw, type of chain, size of trees can be used as a dept guide on saw chain rakers, so if your cutting mostly small trees and bushes, probably shouldn't give the rakers a crew cut. But if using a Husqvarna, the best saw in the world, and cutting big firewood and logs then that is where a mule and a ox will work the best.
:thumbsup:
True, an aggressive chain on little twigs is the worst, and some of the most dangerous sawing I think one can do, other than having things fall on you. In brush, your visibility (of all parts of the bar) can be partial obscured.
Also, I've had little pinky size twigs knock a few chains off the bar upon contact when I didn't have the rpms (and tension) just perfect. Never had that happen in anything over an 1". Thankful for the chain catcher on the bottom of the saw that usually needs to be replaced.
/ Chainsaw chain sharpening....... #44
Stihl makes a fine saw along with others that don稚 have the brand recognition those 2 do but Stihl isn稚 worthy of the blind praise across all models that many people give it.
All my saws are Stihl (MS201, 261, 661 and Grandpas old 028) but that is only because I have a large dealer 5min away. My buddy has mostly Husky saws for the same reason. When I use his saws I don't think they are any better/worse than mine but I do like the Husky off switch better
I also like the M tronic saws better than the older saws
/ Chainsaw chain sharpening....... #45
On the stihl 1/4 turn cap controversy, the NFS has band new stihl purchases because they've had several people burned when those caps geysered fuel onto the operator while they were being opened. I own several stihls with those caps and I would agree, they are not the best design... Other that that, I do like the machines.
/ Chainsaw chain sharpening....... #46
Jonsereds come down the same line as Husqvarna... Same basic saw, but nearly all models of Jonsereds are now discontinued.
I really like mine,
just as I like all the Huskys I own...
SR
^^^^^^^^^^^^Thats what I like to see, cutting wood with a chainsaw helmet, might say I have helmet phobia, nice picture.
Raker dept might have a different measurement on sim chisel vs full chisel, then there are the saw chain for sawing lumber, I only use full chisel. Years ago there use to be a round cutter saw chain, dont think they make that anymore, I thought it stayed sharper on muddy wood, but now I guess theres carbide saw chain for that.
I thought by now there be someone here that uses a feeler gauge to measure raker depth or there be a feeler gauge official measurement on full chisel chain, guess most like the automatic manual Stihl raker file measurement filer mechanism, and some like the good old fashion eyeball measuring technique, AKA barber shop filling, that's been my way for years.
At least we settled the best chainsaw in the world controversy...........................
/ Chainsaw chain sharpening....... #49
Old news. Electrolux bought Husqvarna in 1978, then spun it off in 2006.
/ Chainsaw chain sharpening....... #54
I just ordered the Pferd sharpener after reading the reviews. Worth a try for less than $35.
I think you will be happy with it. It's very easy to use, and you can get good results without having to spend a lot of time learning the technique. There are some minor compromises with this design of sharpening guide, but they are dwarfed by how easy it is to get good results. A stump vise (or other means of holding the saw in place) can really help you get good results, since you can focus solely on the sharpening, rather than also trying to figure out how to hold the saw still.
Due to how the Pferd/Stihl tool sets the depth gauge (aka "raker") heights, with that tool it's important to keep your cutters about the same length. I'm not talking about measuring them with a micrometer or anything, but if you notice that the cutters on one side are getting longer than the other, it's worth it taking a couple extra strokes off the longer ones to bring them back close again. Other hand sharpening systems use what is known as progressive depth gauge height: the distance between the top of the tooth and the top of the cutter varies depending on how far back the cutter has been filed, and the depth gauge is set solely in reference to the tooth it precedes, rather than by laying a gauge across two teeth and measuring down from that (a constant height depth gauge setting system). The former compensates for differing lengths of cutters, allowing them to be different lengths (within reason) without causing problems. The latter (bridging over multiple teeth and measuring down from there) requires that the teeth all be very close to the same length. A progressive gauge also compensates for the different cutting geometry that is formed when the teeth are filed way back, maintaining the chain's performance as the teeth are filed back.
Someone earlier mentioned how few landowners really have the knack for freehand filing (i.e. filing with just a bare round file using no guides or jigs). I would add that there are not all that many people who use a saw professionally who can really get excellent results when sharpening freehand. There are plenty of folks who think they are really good at it. In reality, most are not all that good, or are inconsistent (this does not stop them from sneering at those who use a guide and making some comment like "that's OK if you still need training wheels"). In my life, I have met 3 people who can reliably get results as good as or better than a new out of the box chain with their freehand filing. I've used chains they sharpened multiple times, and have always been impressed. Interestingly, one of them is "just" a landowner, one of them is a pro logger, and one of them is a chainsaw race competitor (and he files his race chains differently than he does his work chains). Sure, lots of people can make a more "aggressive" chain (that's easy). In my book, "aggressive" does not necessarily mean better. I want a chain that's consistent, holds up well, and that is not hard on me or the equipment. With a good guide, most people can learn - in a relatively short time - how to match or beat out-of-the-box performance and reliability. Yes, it's possible to go beyond that with freehand sharpening, but it takes some dedicated time to learn the technique.
/ Chainsaw chain sharpening....... #55
I couldn't imagine not hand filing. When I am cutting all day long, I have to sharpen the chain at least twice, maybe more if the wood is dirty (in which case I'd switch to semi-chisel to get more life between sharpenings).
The only time I use my grinder is when a chain gets really damaged** and I want to salvage it. That normally involves taking off a fair amount of metal, and reduces the life of the chain but is still better than throwing it away. I couldn't imagine using the grinder all the time as a routine practice though.
I think a very basic way to tell if you are filing OK is to look for the difference in performance from before to after. The chain should be throwing nice fluffy chips and cut straight with no bias. Also, if you eventually file the chain to end of life (nothing left to file past the mark) with the edge still parallel to the reference line and all cutters about the same, then it's a good indication you've been filing right. I can't see a way to get to that condition if the filing has been uneven, sloppy, or bad along the way. These things have a way of auto-checking themselves.
I normally only take down the rakers every 3rd or 4th filing, or if I detect that the chain isn't cutting aggressively enough. One of the doodads in my toolbox is a little gauge that lays over the cutters and gives a quick eyeball of the raker depth. Typically I am taking off no more than about 1/3 or 1/2 the thickness of a credit card.
** Regarding damage, the worst is when I hit a piece of metal in the wood, but I also did a number on a chain by grabbing the wrong file one time. I tried using a file for my 3/8" chain on some 0.325" chain because I forgot which saw I was using. It sort of worked but was awful stubborn. I realized what I'd done after about 5-6 cutters, at which point I removed that chain from the saw and hung it on a nail in my barn. That's were damaged chains go to wait for the grinder.
/ Chainsaw chain sharpening....... #56
BTW, I remember having an issue with some cheapo "hobby" chain I had bought from Bailey's one time. I forget the name, something like arborist-pro. It cut fine out of the box, but after a few sharpenings the saw was making really curved cuts and it got so bad that the bar couldn't steer through the curve, so once the saw cut down about half as deep as the bar was wide, the bar would just bind up. Confused me until I saw what was happening. I finally took a look and realized the chain had slightly different cutters left and right, and one was obviously a lot softer metal. That chain went to the trash.
/ Chainsaw chain sharpening....... #57
This topic bleeds more prejudice than the HST versus Gear discussions. Everyone is an expert. :)
LOL, just waiting for somebody to praise his Mac 10!
In French we called them Mayqu'aparte (translated=when it starts) Guess the English term would be POS
/ Chainsaw chain sharpening....... #58
I've had good results with Bailey's house brand chain the last couple years. It does not stay sharp quite as long as Stihl chain but it's close, and it costs less. Supposedly it's made by Carlton now.
/ Chainsaw chain sharpening....... #60
The biggest difference is, one needs a battery, the other difference Granberg is a lot cheaper but if I had to file by hand the Timberline seem like a good option to me. There's something about filing I just cant stand, maybe it's the back&forth motion I dont like.
I hate it too, and never do it!!
I just carry a couple extra chains and change as needed, then grind them when I feel like it.
SR
1996 Ford E-450 Shuttle Bus (A61573)
1996 Ford E-450...
LOAD OUT AND SHIPPING (A65579)
LOAD OUT AND...
2012 FORD E-350 CUTAWAY SERVICE BODY TRUCK (A59912)
2012 FORD E-350...
SINGLE BOTTOM PLOW (A64280)
SINGLE BOTTOM PLOW...
MF GC2300 fel replaced
UNUSED WOLVERINE TDB-11-78W-78" BUCKET (A64281)
UNUSED WOLVERINE...
