Chainsaw and chain holder
   / Chainsaw and chain holder #32
Well, no I'm not jesting. For my needs, I trim face slappers and glass breaker limbs. Your situation must be different.
Oh, a "cab dweller" are we. My woods are so dense CD that I would spend half the day with trimming. It is why I wear my face guard down when in the wood.
Oh, and apparently you do not know about the rule that one is not supposed to get off the tractor except for cinching a choker. (is even that allowed?)
Earlier 80s model M5030. Windows broke out long before I got it. Did like the 6 point ROPS for protection from limbs and roll over. Any tractor in the woods should have enhanced operator and machine protection. Had that tractor and the M59 for three years together trying to decide which one to keep. M59 suited my current needs better. That brings us back to topic of the current modification prototype of saw and chain holder.
   / Chainsaw and chain holder #34
Nice. As I said. Your situation must be different.
   / Chainsaw and chain holder #35
Hi folks. I carry my chainsaws and associated items on my carryall, rather than carry it on the tractor itself. I built it about 15 year ago, and I just finished giving it some new paint and plywood. The frame of it is built out of 14 gauge 1" x 2" box tubing, with some heavier steel where it connects to my 3 pt hitch. Without the plywood on it, it is light enough that I can pick it up. The box is 52" wide and 42" deep. It has really worked out well throughout the years, and it is my most used 'implement'. I have loaded it many times with enough wood to make the front end of the tractor feel like it is floating. I also have a hydraulic cylinder for a top link, which enables me to dump the contents of the box easily. If I did this right, you should see 4 attached pictures.
Corm
Better weather allowed for some fab time.
Cut a 3/8” wedge off the bottom of the tube to tilt the tube back to allow for clearance to be able to scabbard the chainsaw either above or to the side of the tube. The chainsaw to the side brings it more onboard and protected by the loader upright. Had to redo upper mounting holes. Took some time but worth the trouble for versatility.
Thanks for the idea.
Also tacked a rock slider fin to the bottom bracket to protect sheetmetal hydraulic guards.
Spent time working hinged rubber lid idea to help keep out debris. Sometimes get lost thinking how to make improvements.
Next is to weld a hook(s), some loops for long handle tools before welding to base. It’s getting heavier. Slow process.
   / Chainsaw and chain holder #37
You're getting there. Nice work!!!!
   / Chainsaw and chain holder #38
^^^ I agree with ovrszd. I was looking at your before and after pics and noticed the fuel/oil container mounted on there in post #7. That's a good idea. How did you mount that I can't tell from the picture.
gg
   / Chainsaw and chain holder #39
Another weekend to work on this project. Some job scope creep is adding some features. Ground defense guards, fuel/oil container mount, bucket hook, etc.
Checked the bolt up one last time before welding tube to base.
In projects like this, job scope creep is a good thing:thumbsup:
Real nice work smokey!
The fuel/oil container holder idea is in the works. Plan on attaching to the tube with maybe a brace to the rear fender to some factory holes. The bottom will be 3/8x5” flat bar with a 5/8” round bar surround are the thoughts for now. Keeping the robust theme.
Neat container made by Husqvarna. Well made, holds files, saw wrench, wedges, spare chain, and enough gas and bar oil for full day of cutting.
2015 Volkswagen Jetta Sedan (A53424)
2015 Volkswagen...
2018 Chevrolet Tahoe (A55973)
2018 Chevrolet...
Deere 331G (A53317)
Deere 331G (A53317)
2023 John Deere 6155M MFWD Tractor (A53485)
2023 John Deere...
1981 AZTEC SKINNY NECK 31 FOOT FLATBED (A53843)
1981 AZTEC SKINNY...
14179 (A55788)
14179 (A55788)
