Chain sharpening difference?
/ Chain sharpening difference? #101
If you are sharpening out in the woods and don't already have one, a stump vise can be handy. I like the Oregon or Husqvarna stump vises. Stihl is also good, but expensive. Some of the no-name brands have some issues: I tried one that would just NOT stay in the stump, no matter how far I pounded it in.
Oregon Stump Vise
/ Chain sharpening difference? #103
I also find it's worth the time to retension the chain before sharpening. If left slack, the tooth will slant from the file force and impart a weird tooth profile. JMHO
90% of my woodcutting is on my property and a 2 minute drive from my shop. When I sharpen where I cut wood I sharpen it on my car trailer with a wood deck. I just press down and let the chain dig into the wood a little, it’s pretty steady. I do the same on the workbench in my shop. I can see the problem with this being the saw is nose down and harder to get the angles correct.
/ Chain sharpening difference? #105
Nose up or nose down should not be much of a problem as long as the guide you are using is making proper contact with the tooth and the depth gauge. If the saw rocks side to side as you are filing, that can cause the same problem I mentioned as someone lowering the handle of the file as they make the stroke.
/ Chain sharpening difference? #106
What be interesting for some of you to try is square ground chisel. @John_Mc if I remember right you've tried it correct?
/ Chain sharpening difference? #107
re: filing down the drag sections. I filed one chain down too much. It cut very aggresively and made big chips; then suddenly it locked up. Pulled the bar out of the cut and every other tooth was missing.
I went back to the garage to get a new chain, then I discovered the saw motor had a very stout kickback when pulling the rope.
That saw stopped so suddenly it sheared the flywheel key!
Moral to my story_follow sharpening directions.
/ Chain sharpening difference? #108
Been my experience that it doesn't cut any faster than round ground full chisel chain, but does have less vibration.
/ Chain sharpening difference? #109
I've tried it, but not a lot. It did cut faster than round-filed chisel chain. Not overwhelmingly so, but it was certainly noticeable. It also seemed to hold up well.
It's really touchy to get sharpened correctly, and my eyesight just isn't good enough to do it, so I never bothered to learn to do it myself.
I enjoy hand-filing. If someone made a jig that was as easy to use for accurate sharpening in the woods, I'd probably switch to it. (I enjoy hand filing, and the break it provides while working, rather than carrying multiple chains.)
/ Chain sharpening difference? #110
There use to be a few guides available but I haven’t seen one in a long time probably 25 years or so, we use to have one but you’re never as consistent as with the grinder doing them.
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
2017 Chevrolet Tahoe SUV (A59231)
2017 Chevrolet...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
2014 FORD F-350 SERVICE VAN (A62130)
2014 FORD F-350...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
1996 Ford Ranger Pickup Truck (A59230)
1996 Ford Ranger...
