LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,719
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Every area is going to be different as to the availability of AI technicians and what they will charge for travel and labor. Then the difficulty of catching the cows in heat and then the holding chute for the actual insemination.
With a small herd maintaining a small portable feed wagon with stanchions and handling the cows frequently would likely be the least expensive. Including feeding a pail of grain every couple of days, spreading some in a feed bunk and maybe keeping a bit in the bucket to share with all the animals.
"A study reported by Les Anderson at the University of Kentucky looked at the dollar cost per pregnancy when using bulls purchased at various prices. A $3,000 bull used for 15 cows resulted in a cost of about $100 per calf, depending on many factors such as pregnancy rate. While this may not be exact today, it can provide a ballpark idea.
When it comes to costs for AI, many beef cattle are bred using an estrus synchronization program. I am including those costs for this discussion. With a cost of about $20 for synchronization, $20-$40 for semen and about $20 if you need to hire a technician, you are at about $60-$80 without adding in labor.
With a 60% pregnancy rate, you are at about $115 per pregnancy. There are also other costs to consider, such as owning a nitrogen tank and paying to have it filled about every eight weeks, which could amount to $300-$500 per year.
There is not one way to raise cattle that is right for all situations. If your goal is to maximize genetic improvement in your cattle, and you are willing to spend some time and invest in facilities, AI is a great place to start. "
