Catastrophic failure
/ Catastrophic failure #1
Tomtint
Elite Member
Boston
L3700SU
Yesterday I was crossing over a small trench in my yard. Driving the L3700 over a couple 2x8 so the trench would not collapse. One of the 2xs flipped up and caught the hydro filter under the right floor board. Ripped the filter right off along with breaking the housing threads right off inside the filter and bending the rear supply line to the point where that is junk as well. Stupid stupid stupid place for that filter set up...
/ Catastrophic failure #2
Was your ROPS up?
Was your seat belt buckled?
/ Catastrophic failure #3
Sorry to hear about your misfortune, yesterday.
I've noticed that those filters are somewhat exposed.
Hope you were due for a fluid replacement and the rest of the repairs go easy on your wallet.
-Jim
/ Catastrophic failure #6
Too bad about your accident. Sounds like it won't be cheap to repair.
I agree about the vulnerability of that filter and plumbing. It does seem like a bad design. At one point, I thought about making a simple skid plate that would bolt to the FEL sub frame to protect that fragile area. Its incidents like this that make me think a bit harder, especially since I'm now using a grapple.
Good luck with the repairs and keep us posted!
/ Catastrophic failure #7
Luckily the pipe TC220-33310 is $41, the fitting with threads for the filter TA040-33212 is $43 and the mounting bracket TC220-33230 is $8. Not real cheap but not like breaking something major. Use longer 2x8's another time?
  • L3700 hyd filter.pdf
/ Catastrophic failure #8
Laugh of the day and thanks I need one.
I just want to know if you removed your cup in time to save some of that high priced SUDT2 oil ??????:thumbsup:
Ordered the parts today at my local Kubota dealer. The new housing, o rings, rear supply tube and filter came to about $160.00... and probably another 150-170.00 for 6 gallons of SUDT fluid. ... could have been worse I guess.
/ Catastrophic failure #10
Yeah, could have been a lot worse. You were unlucky but lucky.
/ Catastrophic failure #11
No where near as bad as the one where the hydro filter was broken off the transmission case and the male threads were part of the casting of the transmission case. That required the whole transmission case to be replaced. Extremely lucky not more damage was done.
David
/ Catastrophic failure #12
That's why I added a skid plate on my Kioti probably same location. With all the work I do in the woods around stumps I knew it would only be a matter of time.
/ Catastrophic failure #15
/ Catastrophic failure #17
Thanks here is another picture of the plate removed I also made a port with a cover plate so that the HYD oil filter can be removed without removing the plate. It was also a bit tricky getting it in there without interfering with the backhoe sub-frame.
/ Catastrophic failure #20
When you least expect it WHAM something as such happens...part of tractoring. :rolleyes:
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2022 Polaris 1000 Ranger (A64047)
2022 Polaris 1000...
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
