Catastrophic failure
/ Catastrophic failure #11
No where near as bad as the one where the hydro filter was broken off the transmission case and the male threads were part of the casting of the transmission case. That required the whole transmission case to be replaced. Extremely lucky not more damage was done.
David
/ Catastrophic failure #12
That's why I added a skid plate on my Kioti probably same location. With all the work I do in the woods around stumps I knew it would only be a matter of time.
/ Catastrophic failure #15
/ Catastrophic failure #17
Thanks here is another picture of the plate removed I also made a port with a cover plate so that the HYD oil filter can be removed without removing the plate. It was also a bit tricky getting it in there without interfering with the backhoe sub-frame.
/ Catastrophic failure #20
When you least expect it WHAM something as such happens...part of tractoring. :rolleyes:
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60352)
2014 International...
2021 Kubota MX5400 (A60462)
2021 Kubota MX5400...
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
2008 KALYN SIEBERT TRI PLEX FRAC PUMP (A60736)
2008 KALYN SIEBERT...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
2020 DRAGON ESP...
