Catastrophic failure
/ Catastrophic failure #1
Tomtint
Elite Member
Boston
L3700SU
Yesterday I was crossing over a small trench in my yard. Driving the L3700 over a couple 2x8 so the trench would not collapse. One of the 2xs flipped up and caught the hydro filter under the right floor board. Ripped the filter right off along with breaking the housing threads right off inside the filter and bending the rear supply line to the point where that is junk as well. Stupid stupid stupid place for that filter set up...
/ Catastrophic failure #2
Was your ROPS up?
Was your seat belt buckled?
/ Catastrophic failure #3
Sorry to hear about your misfortune, yesterday.
I've noticed that those filters are somewhat exposed.
Hope you were due for a fluid replacement and the rest of the repairs go easy on your wallet.
-Jim
/ Catastrophic failure #6
Too bad about your accident. Sounds like it won't be cheap to repair.
I agree about the vulnerability of that filter and plumbing. It does seem like a bad design. At one point, I thought about making a simple skid plate that would bolt to the FEL sub frame to protect that fragile area. Its incidents like this that make me think a bit harder, especially since I'm now using a grapple.
Good luck with the repairs and keep us posted!
/ Catastrophic failure #7
Luckily the pipe TC220-33310 is $41, the fitting with threads for the filter TA040-33212 is $43 and the mounting bracket TC220-33230 is $8. Not real cheap but not like breaking something major. Use longer 2x8's another time?
  • L3700 hyd filter.pdf
/ Catastrophic failure #8
Laugh of the day and thanks I need one.
I just want to know if you removed your cup in time to save some of that high priced SUDT2 oil ??????:thumbsup:
Ordered the parts today at my local Kubota dealer. The new housing, o rings, rear supply tube and filter came to about $160.00... and probably another 150-170.00 for 6 gallons of SUDT fluid. ... could have been worse I guess.
/ Catastrophic failure #10
Yeah, could have been a lot worse. You were unlucky but lucky.
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2021 Deere 75G (A60462)
2021 Deere 75G...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
