Cat 1 measurements
/ Cat 1 measurements #1
Ozarker
Yanmar 1500D
Went to attach my recently purchased YM tiller to my YM1500 and discovered that I couldn't make it fit. The drive shaft was too long and the top link was too long. I assumed that I had a standard cat 1 set up but apparently I do not.
So plan 'A' was to get a shorter top link and cut the drive shaft. No go............. the shorter top link is for cat 0 and the pins I have are too large. The one I have is 20.5" center to center at it's shortest length.
Then I got to looking at the arms and it seems that the standard cat 1 arms in stock are 32" long. The cat 1 arms on my Yanmar are 24". THAT seems to be my problem. Short arms.
So tell me. what is the length (center to center) on your cat 1 arms? It looks like all my problems will be solved by simply cutting the ends off my arms and adding 6".
Thanks, I remember that. He was responding to me at the time as I was trying to solve my side to side sway. I fixed that.
Looking at those pictures again, the lower arms appear to be about 36" long even tho the ones he made are 26" long. Mine are 24" long and I think I need to alter them to make them 36" long.
/ Cat 1 measurements #4
There are universal TPH replacement kits readily available that should be easier and safer (and maybe cheaper) than trying to modify what you've got. I priced one for my YM240 a couple years back; $125 plus freight I think.
//greg//
/ Cat 1 measurements #5
I had a YM1700 with a RS style tiller. It had a special top link that made it all work out right. A regular top link would not work.
What does RS mean?
Oh, I thought it was a style of tiller.
So why won't a regular top link work? It appears to be setup for a normal 3pt connection.
/ Cat 1 measurements #9
Agri-supply has shorter (13 and 16 inch) CAT 1 toplinks. They also have CAT 0 toplinks (7 and 9 inch) if the CAT 1's are too long. If you use the CAT 0, get a couple of pins and bushings so the fit stays the same.
Much easier and less expenive than cutting and welding your lift arms.
/ Cat 1 measurements #10
That's how the Japanese designed it, who am I to argue /forums/images/graemlins/grin.gif
Actually it pivots in the middle, making the lifting geometry different.
/ Cat 1 measurements #11
My Yanmar tiller would have come with one of those special toplinks had I needed it. The dealer said that they only work with the Yanmar tractors and have to do with the vertical placement of the toplink attachment on the tractor. To get my tiller to fit my Satoh S650 I took an old Cat 1 toplink and cut it down to like 12" clevis to clevis with a couple inches adjustment in either direction. Works great except that you can't leave the pto running with the 3pt all the way lifted b/c the shaft angle is too steep.
/ Cat 1 measurements #12
TSC sells a universal lower lift arm that is something like 31.5" center to center... I have a pair on my YM 1700, and like them.
Keep in mind the yanmar tillers are weird setups.. use short driveshafts and a weird top connection .. and that is where the pivot..
Soundguy
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
John Deere 1770NT Planter Drive (A65640)
John Deere 1770NT...
2017 Subaru Forrester (A62613)
2017 Subaru...
2010 GMC 3500, Crew Cab, 2WD, Dually (A62679)
2010 GMC 3500...
