Case cx36b ownership
/ Case cx36b ownership #41
Nicely done, looks like the case is earning its keep. Have you put many hours on it since you got it? Been pretty trouble free?
Its been good to me so far, not sure on hours off the top of my head but probably 100-150 range. I blew a main hose from the pump to valve body last fall and that made a real mess. It had previously been replaced and who ever ran the replacement hose kinked it and it blew there. Besides that its been trouble free for me.
Anyone know where the heck the coolant drain is? I found a petcock on the front of the machine but that sure smells like diesel.
Found a line off the bottom of the radiator but it doesn't seem to have a drain on it that I can find? Zero visual on the bottom of the radiator though so maybe it's there .....off to find a camera to try and get a look under it. Definitely well hidden.
Found it ....that hose that wasn't attached to anything. Turns out it has a stopper in it and it should drain once removed
The mini has been putting in the work this summer.
Helped a friend trench for a new septic line.
Tore a garage down and cleaned that up into dumpsters.
Took a lot of trees down, stumped, and put in a new septic. It's been run almost every day for at least a few minutes since June probably.
Got a 4ft ditch bucket
/ Case cx36b ownership #46
Are you happy with the Diesel quick coupler? Was thinking about getting one myself.
I totally missed this when you first posted, sorry about that. Yes, it has been WICKED handy and I am glad I purchased it. I swap buckets a lot just because I can and it makes life easier. My Diesel quick coupler is manual and thats okay with me, keeps it simple and only takes about 2 minutes start to finish to swap it over.
I have nothing to compare it to as far as other quick couplers but I have a few hundred hours on it and so far so good.
2009 IMPERIOAL DT7126T 12FT CUSTOM DUMP TRAILER (A66091)
2009 IMPERIOAL...
(APPROX. 29) ASSORTED ROUGH SAWN PINE (A64276)
(APPROX. 29)...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
2019 AUTOCAR XPEDITOR TRASH COMPACTOR TRUCK (A63276)
2019 AUTOCAR...
2012 Jeep Compass SUV (A64194)
2012 Jeep Compass...
