Case 1845c hydraulic pump
/ Case 1845c hydraulic pump #1
damato333
wrightstown pa
ford 555d
I have a case 1845c skid steer. I want to know what size pump it has. They came standard with a 16 gpm pump but I know there was an option to put a 30 gpm pump on. I called a case dealer and basically cause the computer didn' tell him pump sizes he didn't look into it any further. The pump is made by danfoss. So I talked to a danfoss dealer. The guy told me there are numbers on the side of the pump that he needs, so he can tell me a size. There are no numbers on the side. Hopefully someone has the same pump and knows the gpms. I'll post a picture of the tag on the pump. image.jpg
/ Case 1845c hydraulic pump #2
Those weren't the numbers he needed?
I guess not. On case's part diagrams I can find the pump but they give no gpm. It makes no sense why it is so hard to figure out something so simple.
/ Case 1845c hydraulic pump #4
My guess is those numbers are OEM specific for Case and as such they are not allowed to provide any details to anyone other than Case.
A flow meter in the line would be a simple check. Is there a hydraulic house in your area that could run a quick check for you?
/ Case 1845c hydraulic pump #5
I have a case 1845c skid steer. I want to know what size pump it has. They came standard with a 16 gpm pump but I know there was an option to put a 30 gpm pump on. I called a case dealer and basically cause the computer didn' tell him pump sizes he didn't look into it any further. The pump is made by danfoss. So I talked to a danfoss dealer. The guy told me there are numbers on the side of the pump that he needs, so he can tell me a size. There are no numbers on the side. Hopefully someone has the same pump and knows the gpms. I'll post a picture of the tag on the pump.View attachment 427466
Standard pump is a 16 GPM pump with a 30 GPM pump option.
Measure the flow into a 5 gal bucket.
16 GPM
1 GAL = 3.75 sec
10 sec of flow = 1.6 gal
You say it is a Danfoss pump. May be a after market replacement pump.
MASSEY FERGUSON 2605 TRACTOR (A62130)
MASSEY FERGUSON...
2018 VANGUARD REM VXP 53FT T/A DRY VAN TRAILER (A59914)
2018 VANGUARD REM...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
QA 72" Grapple Attachment (A64126)
QA 72" Grapple...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
