Case 1845c hydraulic pump
/ Case 1845c hydraulic pump #1
damato333
wrightstown pa
ford 555d
I have a case 1845c skid steer. I want to know what size pump it has. They came standard with a 16 gpm pump but I know there was an option to put a 30 gpm pump on. I called a case dealer and basically cause the computer didn' tell him pump sizes he didn't look into it any further. The pump is made by danfoss. So I talked to a danfoss dealer. The guy told me there are numbers on the side of the pump that he needs, so he can tell me a size. There are no numbers on the side. Hopefully someone has the same pump and knows the gpms. I'll post a picture of the tag on the pump. image.jpg
/ Case 1845c hydraulic pump #2
Those weren't the numbers he needed?
I guess not. On case's part diagrams I can find the pump but they give no gpm. It makes no sense why it is so hard to figure out something so simple.
/ Case 1845c hydraulic pump #4
My guess is those numbers are OEM specific for Case and as such they are not allowed to provide any details to anyone other than Case.
A flow meter in the line would be a simple check. Is there a hydraulic house in your area that could run a quick check for you?
/ Case 1845c hydraulic pump #5
I have a case 1845c skid steer. I want to know what size pump it has. They came standard with a 16 gpm pump but I know there was an option to put a 30 gpm pump on. I called a case dealer and basically cause the computer didn' tell him pump sizes he didn't look into it any further. The pump is made by danfoss. So I talked to a danfoss dealer. The guy told me there are numbers on the side of the pump that he needs, so he can tell me a size. There are no numbers on the side. Hopefully someone has the same pump and knows the gpms. I'll post a picture of the tag on the pump.View attachment 427466
Standard pump is a 16 GPM pump with a 30 GPM pump option.
Measure the flow into a 5 gal bucket.
16 GPM
1 GAL = 3.75 sec
10 sec of flow = 1.6 gal
You say it is a Danfoss pump. May be a after market replacement pump.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2022 EZ-GO ELITE...
New/Unused Landhonor No Till Seed Drill (A65583)
New/Unused...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
43018CFL (A59228)
43018CFL (A59228)
