2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,593
Another thought--years ago before aluminum storm windows went on houses, they used to attach an outdoor screen at the top
from the outside and then it was held at the bottom by a hook that held the whole thing in place.
Each side could be built as an independent panel with its own frame that hangs off the top of the frame you've just built and then the side panel would lock in place with a couple of bolts at the bottom. You could put a lip or something at the top of the panel so you can lift into place, and it will stay on its own until you finish bolting it on.
