cab project
/ cab project #21
Another thought--years ago before aluminum storm windows went on houses, they used to attach an outdoor screen at the top
from the outside and then it was held at the bottom by a hook that held the whole thing in place.
Each side could be built as an independent panel with its own frame that hangs off the top of the frame you've just built and then the side panel would lock in place with a couple of bolts at the bottom. You could put a lip or something at the top of the panel so you can lift into place, and it will stay on its own until you finish bolting it on.
/ cab project #22
Dirtnut :
i thought about using expanding spray foam in the tubes. drill a small hole in the middle to fit the straw nozzel in and a small hole at either end to let the air escape as the foam is injected,this should help insulate & keep the steel from sweating.
I strongly advise you not to do this.
These foams make a so called 'skin' on the contact surface. As they do not glue to metal too well, air and water will get trapped between the foam and metal and accelerate corrosion. These foams are even able to absorb water in their outer layers where the gasbubbles are open.
My tatra which was converted to a mobile hunting home by the previous owner was isolated with this spray foam and when restoring it i found that the wooden frame and metal were rotten. This was after a 3 year period. When removing the foam i had to use cloths to take up the water trapped between. It was hard to believe that so much water could be there. The oak frame was in places a sponge, I am not kidding you, you could take out pieces of wood and press out the water by hand.:eek:
just to give a bit of an argument to my advise.
/ cab project #23
What about using acrylic for the windows?
It will break easier than polycarb but so does glass.
With acrylic you can buff out most imperfections. We have a surplus store here that sells decent sized sheets of it and I have used it before for different things. It cuts easy with a jig saw.
Just a thought.
/ cab project #24
Dirtnut,
Your project is looking good so far. I'd like to offer a little advice about the windows though. I put a soft sided cab on my B7500 a couple of years ago. But I lucked out in that I bought a used old cab from a friend. It was really old and I had to make new sides as well as some other pieces. The front panel has a decent sized window with round edges like some school buses. But the window was cracked and I wanted to replace it. The thick rubber edging was a bit dried out and I ended up just cutting it away. I went to a local glass shop and they cut me a replacement window. Just like the original this was 1/4 inch Safety glass. They told me that all this type of equipment should have Safety glass which I also think is a good idea. They also had replacement rubber striping which was a little difficult to use but it looked great after it was all done. My window is about 18 x 24 and, including the rubber strip, cost $52. A small price to pay for safety. If you decide not to use Safety glass do not use plexiglass because it can shatter. Use Lexan instead. This is the plastic stuff used for bulletproofing banks and other businesses.
/ cab project
well i got half of the grinding done today, almost finished the door will have that done tomorrow. then i will start the swing open window frames.
2manyrocks- not sure about the rops yet. i have small 3/16 angle i am going to try for the window frames, will gusset the corners this should be stiff enough.
tatra805-thanks for the info think i will scrap that idea.
sld-i will check into that when i get closer to glass install.
/ cab project #26
Dirtnut,
One thing I forgot to mention in my message about the window is that part of the beauty of this system is one only needs to cut a hole in the sheet metal slightly larger than the window. No frame is needed as the rubber mounting strip becomes the frame. This might make your construction a little easier.
/ cab project
that wont work for what i have planned. i need to make frames because my side & rear windows will be hinged so i can open them, the one on the door will be hinged on the door frame so i can open it independant from the door. at least this is what i plan (trial & error) but this is how we pay for our education spending money on things that we find out doesnt work. that is why my check book is always broke.
/ cab project #28
Dirtnut, I did a cab project about 10 years ago for my ford 1310. I made the cab in several pieces so I could remove it in the summer as I have trees to mow under. I made it an awfull lot like yours with only one door. I now have a kubota b7510 and retrofit it to this tractor but I made 2 doors this time as I was not happy only being able to exit one side. I used 3/4x3/4x1/8 square steel tube with aluminum sheet to skin the top and partly down the sides. I went to the local wrecking yard and and got some windows out of a micro bus. I used plexi glass to skin the rest of the cab all windows and skin are very dark and makes it easier on your eyes in the winter sun. The front window is clear glass to see at night. the door windows are from a jitny from work. I atached all the windows and plexiglass with self drilling and self tapping screws.
viewpic.php
[/url][/IMG]
viewpic.php
[/url][/IMG][/IMG][/IMG][/IMG]
/ cab project
that is a nice cab, i do not plan on taking mine off that is why i hope i can make window frames that swing open. as far as 2 doors the way the loader valve has to be mounted i could not use both sides of tractor anyways.i would have to buy a differant set up. i made a wide plate bracket on that side for the valve and have plenty of surface area to add more valves or hydraulics.
/ cab project
i got the door almost finished today,need to do a little more welding.did get the window frame done on the right side, i am not sure if i will be able to glue tempered glass in these they do flex a little, maybe the glass will stiffen them up without breaking (any ideas?). or should i skin the frames & use gaskets.
/ cab project #31
Great work you are doing on the cab, i am wanting to build one for a
jd4300 but the windows are the problem i have. I can"t decide which
way to go right now. I have a backhoe attachment so the rear window
might need to be fixed so i can take it out sometimes. after seeing your last post about gaskets thats probably the way i will go.
I seen a post a while back (cab in progress) and he glued tempered
glass in. But you have a good point that it may flex some with the tractor.
Keep up the good work and the pictures to.:D
/ cab project
i dont think the windows will flex with the cab but the frames flex in and out and i dont know if the glass will be ok, if they will add strength when glued or if they will break. most crank windows on houses are only frames & they must flex some until the glass is installed, then does the glass stiffen them up? this is what i am wondering. for the rear window i am going to hinge mine to swing into the cab & latch up on to the ceiling that way it is out of the way but always there to let down.
/ cab project #33
well i did get a little welding done last night late 11:00. went to grizzly tools in a snow storm to pick up two new power tools for my shop and of course i could not wait till morning to play. used the welder what a dream after using an old lincoln stick for years.did make a couple cuts with the bandsaw works great but time will tell. probably wont get anything done today,need to get out & plow snow sure wish my cab was done.
I have that same Grizzly bandsaw and it's a great tool to have, especially when you need to cut miters.
/ cab project #34
Houses don't vibrate the way tractors do, so I wouldn't glue any windows in place. It will be a royal PITA to replace any that break. If you can avoid plastic windows, that would be good too as they will scratch badly with time requiring replacement. Attached is a down and dirty drawing of a method I'm thinking of using if I ever build a cab for my 4200. I've seen this method used on Deere tractors. The weather stripping can be obtained from McMaster-Carr. www.McMaster.com
  • Drawing1 ANSI A (1).pdf
/ cab project
yes this bandsaw is great but time will tell. i love the fact that the head angles instead of the clamp so u dont need 40 acres to cut angles on long pieces of steel. well i made up my mind i am going to skin the frame and window frames and use gaskets, this we know will work, the glueing might turn out to be an expensive education. glass is the only thing i will use.long term it will only need replaced if broken,plexiglass gets scrached and cloudy after awhile.
/ cab project #36
The swivel head was the selling point for me on the Grizzly bandsaw for the same reasons you mention about a conventional chop saw. Jet and Northern Tool offer the same saw now too. I like Jet's stand better, and Northern just had the factory paint it a different color.
Keep the pix coming on the cab project.
/ cab project
didnt get much done yesterday finished grinding,measured for sheet steel, gasket material,did some looking.might make a change to the swing open windows.the rear window cant swing in it wont clear the rops it will have to open out.i should be back at it next week need to order steel and run for supplies for the shop today.
/ cab project #38
Where are you going to get your glass from?
What kind of glass are you using?
I think using gaskets will be much better, you could take one out
if needed. when i start mine i will probably fix the back window on
hinges, so i can take the whole frame out. my backhoe attachment
stays on most of the time and it has a seat with it,and i don't have
much room to swing a window out.
keep us posted with your work, great job you are doing.
(I refuse to buy a cab from any dealer.):D
/ cab project
i am not sure where to get the glass will probably use the yellow pages & have a glass person come out & do it. i plan on using 1/4 tempered glass. my side & rear windows will have bolts with lock nuts for the hinge pines. the side windows will open 180 degrees & latch at the back. the rear window will open out as far as what ever length the shock will be. with using the bolts i can also remove the windows.
/ cab project
well i got a little done today went & picked up 2 sheets of steel 16-gauge 4'X8' to skin the cab. i got a little side tracked when a customer came in & needed a snow plow built for a 100 ton rock truck. i couldnt say no he said he would help me,so an our later we had it done & it works great the customer was very happy. now i did get the one side window skinned still need to cut the opening for the window. does anyone know if there is a minimum radius for rounded corners for glass.i would like to round the corners so the gasket is all one piece with one seam where the two ends will meet.
2014 Freightliner 114SD T/A Dump Truck (A64556)
2014 Freightliner...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
PALLET OF TRACTOR WEIGHTS (A64278)
PALLET OF TRACTOR...
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
2008 SELLICK S-80 ROUGH TERRAIN FORKLIFT (A65053)
2008 SELLICK S-80...
