Cab Heater question?
/ Cab Heater question? #1
Craftsman2000
Windsor, Colorado
Ford 1910 with loader
Hi I am new and I recently bought a 1985 Ford 1910 tractor with a Sims cab on it. I was planning to do some snow removal with this tractor soon and wanted to make my own cab heater using an automotive heater core. What is the best way to hook this up to the coolant system? Any advice would be much appreciated.
Thanks, Tyler
/ Cab Heater question? #2
Good morning C2000
I have done this several times over the years and recently installed a heater in both of my Curtis cabs. What you want to do is route the inlet of you heater core to the outlet side of your engine thermostat. If you do not have a pipe plug at your thermostat housing, then find a coolant port on the cylinder Head and run a 1/2" or 5/8" hose to the heater. The return hose from your cab heater needs to be run to the inlet of the engine water pump. Hopefully you will have pipe plug near the water pump inlet. If not, you can purchase a T or Y hose connector to install in the lower radiator to water pump hose. This connection will provide positive coolant flow through your cab heater core.
Good luck with this...
Dan
Thank you very much Dan, That was the info I was after. I will let you know how it goes.
/ Cab Heater question? #4
I installed this heater in my cab heater coil.JPG tapped into the bypass hose by pass hose.JPG installed a 4" 12v fan behind the core. Keeps the cab 40 dg warmer than the outside temp. Had the core, fan an switch hose $20.00 total.
/ Cab Heater question? #5
Nice picture jb62901, you have a nice shot of the thermostat housing.
What type of coolant hose did you install, I've not seen this around my neck of the woods.
C2000, I've never posted a picture on TBN yet, but I can if you think a shot of my hose routing (on Kubota though), might help.
Dan
/ Cab Heater question? #6
D W I got the hose at Lowes have since changed it out for 3/8" heater hose. The other hose was to soft.
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
2022 EZ-GO ELITE...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
LAYMOR SWEEPMASTER 400 (A65643)
LAYMOR SWEEPMASTER...
2017 Peterbilt 579 (A64127)
2017 Peterbilt 579...
