BX15 vs BX18/23
/ BX15 vs BX18/23 #21
"I was just wondering if anyone with 3 cyl Kubota ever runs into engine bogging while mowing slopes in high range."
Yes, with a BX-24 it will bog in high range in high grass and 60 inch mower. Of course maybe it would not have if it did not have the FEB and B/H mounted.
/ BX15 vs BX18/23 #22
Simply, yes my bx 1850 will bog on steep inclines in high or low while mowing it all depends on the grass and moisture level.
I hope that answers your question.
/ BX15 vs BX18/23 #23
jbordwine said:
First off, I appreciate everyone's concerns about going too fast up & down hills.
jbordwine said:
First off, I'm not an idiot,
Hmmm, is that first off or second off?? :) (Just Kidding) As far as the word idiot, nobody here has done any name calling. Most people on this board have a lot of good advice and I don't see any attempts to imply that you are unknowledgable. People are enthusiastic about their tractors and most of what they share is out of the goodness of their hearts.
I used to teach Physics. There are just too many other variables to reduce this question to three cylinders, uphill slopes, and high range. On the first cut of the season, after the tall fescue has finally dried, but is 18-20 inches tall, the MMM on my BX2200 can bog down in low range while going downhill. You have said you keep the blades sharp, so that variable is addressed. The other factors though are: steepness of the hill in degrees, species of grass, height of the grass, internal moisture content of the grass, degree of wetness/dryness of the grass on the outside (in relation to clogging the deck and chute), type of tires you are running, whether you are in 2WD or 4WD, degree to which these tires are getting traction on this particular grass at whatever degree of wetness it is, height you have the MMM set to cut at. There are just too many variables for any of us to know what a 3 cyl. BX will do on your slope, cutting your grass.
Again, my 3 cyl. BX 60" MMM will bog even in low range going downhill when the other variables are offering great resistance, so certainly it would completely stall going uphill in the same grass in high range. On the other hand, if the grass only needed an inch taken off, and it were very dry and I were on a 4 degree incline, I have no doubt that I could race uphill in high range and have no problem. I have brush hogged in high range at full speed in medium density field grass that is dry, but the rotary rough cutter is an entirely other beast than the MMM.
I really do wish any of us could give you a definitive answer on this, but we just don't know all those other factors. Maybe you could fill in some of those unknowns for us. You have said the Husqvarna had no problem, but the BX1500 bogs in high range on this slope. Given all those other unknowns, I think the only way to know for sure is to have someone bring a 3 cylinder model over and actually try it and see. I had serious doubts that a BX with backhoe could dig in my duripan. I debated for 5 years about spending $5.6k for a backhoe. I asked a TBN member who is a neighbor, BX23Barry, if he would bring his BX23 over for a test dig. He brought it over, the bh dug in the duripan, and I bought a Woods backhoe for the BX2200. It arrives Wed., and I feel like a kid on Dec. 24. (Thanks Barry Claus. The CFO at my house would not have authorized the funds had it not been for you!!!)
I do hope this helps at least a little. If it doesn't, I really am sorry and I do wish you all the best in this agonizing decision. I have been in your shoes and it is scary thinking about spending big bucks when you aren't sure if the machine will deliver. Good Luck !!!
/ BX15 vs BX18/23 #24
Concur on the humor. They get scrambled around that way sometimes.
Regarding your question:
I mow exclusively in high range. I bag (PTO shaft driven) and have the 60" deck, so there is about as much load there as possible. I also have very significant slopes.
Bear in mind that this is my manicured lawn, not pasture grass. I only whack an inch or 1.5 inches at a time and not when it is wet (clogs bagger and isn't healthy for grass).
I can do whatever I want, whenever I want and I have never bogged the engine. I mow at nearly WOT (lever at even 3:00 from steering wheel on this generation). I have shifted into low for some "delicate" maneuvers, but it has been for control, not for lack of power.
For giggles, I went on one of my steeper spots and, with the bagger full, the mower and bagger on, and in high range, punched the treadle forward to see if I could get some response from the engine. In that extreme and intentional case, it did drag down a big, puff a little smoke, and didn't miss a beat.
In the situation you describe, a BX1500 with a 54" deck on a slope in high range...I can see that being a bit of chore for that smaller machine.
I hope this infomration is helpful to you or otherwise helps with at least part of your question.
/ BX15 vs BX18/23 #25
Like I said I just run mine in low range but gave High a Try while
working the BX23 and BX1500 today.
The BX 23 would not even move on a hill in high.
Mowing on a slope in high with the BX1500 I noticed I had to let way off on the petal to get enough power to move the tractor and mow.
In high the travel speed was as slow or slower than the travel speed in low so I don't see where you gain any time by mowing in high.
/ BX15 vs BX18/23 #26
LOOKS LIKE YOURE HAVING A LITTLE TROUBLE WITH LACK OF POWER WITH THAT LITTLE BX1500. :p
/ BX15 vs BX18/23 #27
I have a BX24 with 54" mmm. I mow in high ALWAYS. I mow considerably faster than I can go in low. No problems with hills. Besides my lawn, I occasionally mow about an acre when it gets about 8 inches tall. I still use high. Takes about 25 minutes. Would be quicker if the ground were smoother.
I remove the FEL and BH to mow.
I can't seem to get my grass to grow thick enough to bog the engine.
/ BX15 vs BX18/23 #28
Concede that with BH mounted and FEL loaded, it is easier to step off a slope in low range. But that isn't what we're talking about here.
If that is true for ANY of your machines, I have no explaination. I can 100% assure you it is not true for mine.
I'm curious as to just how daft you think we are? If mowing in high was stressing the hydraulic system SO MUCH that it couldn't physically move any faster than in low, do you really think we'd mow 1, 2, and 3 acre lawns in that condition? C'mon. Give us some credit, here, please.
/ BX15 vs BX18/23 #29
LOL.....
It can be argued that a BX22/BX23/BX24 will have a hard time climbing a steep grade in high range when it has implements attached to it that in effect almost doubles it's weight, i.e. BH, FEL & 60" MMM weighing in at approx 1050 - 1300 lbs.
So the most logical thing that one can do to increase it's performance and allow it to mow steep inclines in high gear is to rid the tractor of it's unnecessary weight, i.e. like remove the FEL & BH which are not needed to finish mow (Not to mention how they cut down on the manuverability of said tractor), but, the train of thought of a particular poster that claims that he cannot climb a steep hill while mowing in high w/his BX23 is not to lessen the unnecessary weight of his BX23, no sir, but to purchase two more BX's to mow it. :D
Tis hard to debate against logic such as that :D :D :D :D
Good luck boys & girls :D :D :D
/ BX15 vs BX18/23 #30
JohnSinVA said:
On another note, would stepping down to the 48" deck enable your 1500 to handle the mowing chores in high range? You're losing some cutting width but potentially picking up mowing speed.
People with 54'' decks on a BX1500 report plenty of power to handle it.
Kinda makes me wish I had the 54'' one on my BX1500.
I'd let my 48'' one go for $850.
/ BX15 vs BX18/23 #31
LBrown59 said:
I have have a bx1500 and a bx23...
The bx23 is no better at mowing in hihj range that the bx1500 so
Tune in tomorrow, folks, to the exciting conclusion to the preceding sentence! :p
/ BX15 vs BX18/23 #32
1*All on the 2.33 acres.
2*Things were let go here for 30 years because I couldn't afford a tractor to maintain the place with.
I didn't have the money to hire stuff done either.
Believe me things can really go down hill in 30 years of neglect.
The backlog accumulation was tremendous when I got the BX23 back in 2004.
In reality the 950 hours I put on the BX23 is but a drop in a bucket compared to the 262,800 hours that the property suffered from neglect; so no I haven't covered it all as there is still much catching up left to do.
3*I have.
4*No I don't.
David Cockey said:
1* Have all/most of the 933 hours been on you 2 1/3 acres?
2*If so is there any of your lot untouched in the last 3 1/2 years?
3* have you experimented with High?
4* Do you normally push the hydro pedal all the way to the floor?
/ BX15 vs BX18/23 #33
When I hit the post reply button the computer went crazy doing all kinds of weird things then locked up and shut down.
I couldn't get back on line to view the thread or do any editing .
This and the other post above it are not what I had tried to post as my orginal post never got posted.:rolleyes:
I never even got a chance to view the thread let alone make any corrections.:mad:
/ BX15 vs BX18/23 #34
Post
31 32 33 34 35 36 37 38 39 & 40
were caused by a computer glitch.
In fact my actual post never got posted.
How do I delete these unauthorized posts?
== L B ==
I did not know they were even in the tread until today.
/ BX15 vs BX18/23 #35
Yes, Administrator. Please let us know how to delete Mr. Brown's posts.
Kidding, Lee. We're not always eye-to-eye, but I appreciate your devotion to your own ideas. Nothing but respect, I promise.
Please don't take it wrong...I really make this request with the greatest of all sincerity...I'd LOVE to see what 2 acres with over 1,000 tractor hours devoted to it looks like. I promise, I don't mean that with any mal-intent. I know what 180 hours looks like, and it looks pretty darn good, except for a few weeds because I didn't put a pre-emergent down this spring...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
Woods RM59 Finish Mower (A62613)
Woods RM59 Finish...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
Gehl Mix-All 95 Grinder Mixer (A66408)
Gehl Mix-All 95...
