1845 problem
/ 1845 problem #41
It just dawned on me that some Deutz engines have an external solenoid that opens the fuel flow via a spring and rod connected to a spring shut lever on the injection pump. If that's the case here, the solenoid needs adjusted so it can fully retract. Is that the case here or is the shut off solenoid bolted directly to the injection pump?
The more recent versions of the Deutz engines (1011, 2011 series) used on Power-Tracs have solenoids with internal engagement of the fuel shutoff, and no adjustment needed or possible.
All the best, Peter
/ 1845 problem #43
I would get a V lightbulb and put it across that circuit that has the power and while the unit is grounded out somewherein the circuit the lightbulb will stay lit. Go along the circuit disconnecting individual items on that circuit until the light goes out when the light goes out, you found your problem. If you don’t have your wiring diagram for your unit, you can call Terry and he should email you a copy of the wiring diagram for your unit.
/ 1845 problem #44
Found a PT1845 wiring diagram online. This appears to be a combination diagram from several previous versions that coxontools created. Posted as a new thread. Might help you?
/ 1845 problem
Got a new wiring diagram from Terry yesterday and it is about the same as the one I had that was in the owners manual except the one of the rear wiring which was dated 2009 and my machine is a 1995 I guess they changed the wiring in the rear part of the machine. Terry and I discussed several different things to try but still kicks circuit breaker in about 25 seconds . Terry and I both wonder if it might be the new fuel shut off solenoid or wiring harness or plug , as I never had any problem till I installed the new one along with the wiring harness. Have checked all wires I can find and no signs of bare wires touching anything
/ 1845 problem #46
That sounds like an easy test. Have you tried just disconnecting those two individually? E.g. the fuel solenoid plug, and then the engine harness connector?
Did you get a two wire or a three wire solenoid?
All the best,
Peter
/ 1845 problem
I have not tried either I didn't think about doing that and the fuel shutoff is 2 wire.
/ 1845 problem
FINALLY got problem solved, took it out and mowed for about 30 minutes circuit breaker did not trip so I think it is ok
/ 1845 problem
And the problem was?
The wiring harness I got off ebay ended up being the problem. The 2 wires that go onto the alternator came with the terminal ends already on them. one was a ring connector and the other was a slide on connector which was the way the old harness was , well the connectors on the ends should have been the opposite of what they were, changed the ends and put on alternator and it has not tripped the circuit breaker since then and I used it mowing for over 30 minutes so I think everything is good. don't know if it was made late friday afternoon or if some applications might use a different setup. Thanks to all for suggestions as what to look for
/ 1845 problem #53
@ernemats I'm glad that it is working for you now! Congratulations on fixing it.
Out of curiosity, why did you need an eBay engine harness to begin with?
All the best,
Peter
/ 1845 problem
All the best,
Peter
The old wiring harness was nothing but bare wires, I don't know if the mice chewed all covering off or if just old age deuteriation but none of the wires had any covering on them.
/ 1845 problem #55
Wow! That will do it.
I'm glad that it is fixed.
All the best, Peter
2020 Chevrolet Tahoe (A68183)
2020 Chevrolet...
2008 Mini Cooper Hatchback (A66738)
2008 Mini Cooper...
20ft 4-Door Shipping Container with Shelving (A64553)
20ft 4-Door...
2018 CATERPILLAR 259D SKID STEER (A65056)
2018 CATERPILLAR...
2016 Nissan Frontier Crew Cab Pickup Truck (A66736)
2016 Nissan...
2019 Peterbilt 520 T/A EZ-Pack 40Yd Front Loader Garbage Truck (A66736)
2019 Peterbilt 520...
