BX 2680 Throttle
/ BX 2680 Throttle #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
Hi all,
Just curious, anyone else have a throttle lever from **** on the new 80 series BX's?
I mean really, it should not be that hard to operate the throttle. Mine is so hard, I feel
like i'm going to break it off...
Thanks
Dave
/ BX 2680 Throttle #3
This is little bit old of a thread but I will comment on what recently happened to me. Mine worked its way loose and the bottom nut spun right off. Replaced it with a nylock nut, much easier to get tension you like without worry it will loosen itself. Not sure why they wouldn't do that in the first place.
/ BX 2680 Throttle #4
My 2370 has the same problem and I may try that too.
A few nuts on the hydraulic control linkages have been changed for the same reason after we experienced slow bucket problems, there were a couple that had come loose, nylocks fix a lot of problems.
/ BX 2680 Throttle #5
Any chance you remember the thread size? I don't have any metric nylocks lying around, so I'll need to buy one.
/ BX 2680 Throttle #6
M8, Standard thread pitch (if its not labeled with a pitch then its standard, if it has a label I think 1.25 is considered standard.) I got mine at a local hardware store.
