BX 2680 Throttle
/ BX 2680 Throttle #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
Hi all,
Just curious, anyone else have a throttle lever from **** on the new 80 series BX's?
I mean really, it should not be that hard to operate the throttle. Mine is so hard, I feel
like i'm going to break it off...
Thanks
Dave
/ BX 2680 Throttle #3
This is little bit old of a thread but I will comment on what recently happened to me. Mine worked its way loose and the bottom nut spun right off. Replaced it with a nylock nut, much easier to get tension you like without worry it will loosen itself. Not sure why they wouldn't do that in the first place.
/ BX 2680 Throttle #4
My 2370 has the same problem and I may try that too.
A few nuts on the hydraulic control linkages have been changed for the same reason after we experienced slow bucket problems, there were a couple that had come loose, nylocks fix a lot of problems.
/ BX 2680 Throttle #5
Any chance you remember the thread size? I don't have any metric nylocks lying around, so I'll need to buy one.
/ BX 2680 Throttle #6
M8, Standard thread pitch (if its not labeled with a pitch then its standard, if it has a label I think 1.25 is considered standard.) I got mine at a local hardware store.
(2) 330 GALLON POLY TOTES W/ CAGES (A62131)
(2) 330 GALLON...
Zero Turn Mower (A59231)
Zero Turn Mower...
John Deere 1025R Tractor (A64047)
John Deere 1025R...
2015 Volvo L30GS (A62180)
2015 Volvo L30GS...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2860 (A56857)
2860 (A56857)
